New FIC 1100cc High impedance Injectors
Old Feb 9, 2010, 10:52 AM
JohnBradley's Avatar
I just wanted to let you know that Fuel Injector Clinic 1100cc/min high impedance custom injector is NOW available. FIC’s 1100cc fuel injectors are the largest high impedance injectors with Evo/DSM (EV1) plug and play fit.
The magic of this 1100cc injector is in the latest fuel injector technology, which makes it a very linear injector. And the 1100cc injector provides great trailing throttle response and minimum pulse widths resulting in a perfect cold start and idle.
We are currently testing them in a 2.4 project here on E85, a Skyline, and 2 of our turbo quads.
Here is the pix-
A set of 4 is MSRP at $450
Old Feb 9, 2010, 11:00 AM
Right now the car is also on E85 and these injectors are VERY responsive.
FWIW-
Displacement- 2.4
Cams- S2s
Omnipower 4 bar
SD settings-
MAPVE- the same one I always post up
RPMVE leaned at idle to 93-99, 100-102% out the top
Scaling- 522
Latency-
11v- 1.032
14v-.744
Old Feb 9, 2010, 11:35 AM
GST Motorsports's Avatar
522 scaling on E85 for a 1100cc injector? Seems a little low. Even the RC 1000cc's scale at 590-60X on E85.
What size motor?
- Bryan
Old Feb 9, 2010, 01:00 PM
EvoM Moderator
scheides's Avatar
Those are on the 2.4L he mentioned maybe?
I have my FIC1050s dialed in *perfect*, is there any reason to upgrade to these? Or would it be better to just recommend them to others, and use them if I ever do another car?
Old Feb 9, 2010, 03:52 PM
If you have the 1050s and love them, continue to use them.
With my current method of SD, displacement is a direct ratio on scaling. On my car for instance 10% displacement meant I had to change the scaling from 1624 to 1462...almost exactly 10% more fuel for 10% more displacement. I would suspect on a MAF car that these would be somewhere in the 800s on a 2.0.
I updated that post with relevant information
Old Feb 9, 2010, 07:18 PM
Just noticed that Jens included a latency chart as well-
Old Feb 9, 2010, 07:24 PM
mayberry's Avatar
I have a set of RC 1000CC's that I had on the BBK 2.0. I'm in the process of a 2.4 build and have been considering a different injector for a few reasons. I have a full-blown set up on stock lines and rail. Would you suggest these over say PTE 1200's or RC1200's?
Old Feb 9, 2010, 07:37 PM
mrfred's Avatar
The long snout doesn't get in the way of anything?
Old Feb 9, 2010, 10:56 PM
mayberry's Avatar
It probably sits right outside of the intake port. I'm assuming that's to help with fuel atomization?
Old Feb 10, 2010, 04:26 AM
Fast_Freddie's Avatar
I was wondering the same thing... Looks a bit long...
Old Feb 10, 2010, 08:08 AM
EvoM Community Team
fostytou's Avatar
I was thinking this was an Evo X style injector, but I didn't want to be the first one to jump out about it
Old Feb 10, 2010, 08:52 AM
Evo X, Yamaha 700R and a few others use that style. It is an atomisation function but going either way (away from it or using it) doesnt seem to affect anything. I'll put on in an intake and see where it sits and take a pic.
Old Feb 10, 2010, 09:00 AM
mayberry's Avatar
Also, where would these be available. I haven't seen them on FIC's website.
Old Feb 10, 2010, 09:06 AM
They are technically still pre release. Being a FIC dealer and testing these I was allowed to post the information. They should be on the site shortly, but yes over those injector choices I would definitely grab these first.
Old Feb 10, 2010, 10:01 AM
It sticks down a little but where that sits in the injector pocket in the head its not 'in" the way. I put a pic of the DSM in so you can see how it would mesh up into that pocket on an Evo head (or approx.)
Evo-
DSM head for reference-
Quick Reply: New FIC 1100cc High impedance Injectors
