testing the new FIC 1100 cc/min saturated injectors
Old Apr 19, 2010, 03:02 PM
mrfred's Avatar
update
Update: I've got at least five tanks of E85 through the my Evo with these injectors, and the injectors are still perfect. Idle to WOT is all excellent. Still starts perfect under all conditions.
Old Apr 19, 2010, 04:52 PM
GregM's Avatar
Great to hear, I'll hopefully have some on their way to me this week.
Old Aug 26, 2010, 02:51 PM
R/TErnie's Avatar
thanks for the work MrFred. I've been dealing with my ID1000's... I think its time to switch
Old Oct 13, 2010, 08:57 AM
vr4_rider's Avatar
Originally Posted by mrfred
I haven't tried the BlueMax 1250s, so I couldn't say which is better. Bryan has commented a few times that the BlueMax's seem to work pretty well. All the propaganda on the internet says that the advantages of the new generation of high impedance (Bosch) injectors over low impedance (BlueMax) injectors is better pulsewidth consistency at low pulsewidths (idle, cruise), a more linear fuel delivery as a function of pulse width, and a finer mist of fuel with a wider spray pattern. The FIC1100s behave pretty much like my FIC1050s with the exception of a more stable idle, and slightly better gas mileage. One issue that is not specific to injector type is warm starts. Some warm start well while others warm start poorly. There is still no definitive answer on why some are better than others. My FIC1100s are warm starting fine on E85. Have yet to try gasoline.
Shunting the resistor pack is pretty easy. If you do a search in the ECUFlash forum, you should be able to find some pics and a description. There is also some info in the AEM forum where there is an ID1000 thread.
Traditionally, low z injectors are better at idle and cruise. The bluemax injectors came out to fulfill these conditions better than the older low z injectors. The high z bosch injectors is supposed to be better than the bluemax, which is supposed to be best at idle/cruise?
Thanks!
Old Oct 13, 2010, 09:22 AM
mrfred's Avatar
Thanks!
I think that depends on how the injectors are being driven. A P&H driver may give very good idle and cruise on low Z injectors, but the Evo injector driver is the battery voltage. :-) Converting to high Z allows elimination of the resistor pack and any consequences of slightly different resistance between the resistors on injector response characteristics.
Old Nov 2, 2010, 12:47 PM
Tbtalon94's Avatar
Anyone Else have Scaling/Latency Values they'd like to share?
Mine seam a bit out of whack for some reason:
FIC 1,100's
93 octane pump
Scaling: 943
Latency:
3.312
2.112
1.656
.984
.528
.336
.216
I either have to go WAY high with scaling or lower the latencies a lot otherwise my trims go way lean and sometimes max. Anyone have any recommendations? I'm on SD BTW.
Old Nov 2, 2010, 04:49 PM
mrfred's Avatar
Those latency values are way too low. Your SD calibration maps probably need tweaking.
Old Nov 3, 2010, 05:24 AM
Tbtalon94's Avatar
Here is what I've got.
With this set-up my trims are withing +/- 2%, startup is great, idle is great, etc. etc.
If I reduce the VE vs RPM tables then raise latency i have a pretty bad stumble right off idle that effects driveability a lot.
What do you recommend mrfred?
Attached Thumbnails testing the new FIC 1100 cc/min saturated injectors-injectors.jpg
Old Nov 3, 2010, 07:09 AM
mrfred's Avatar
in concept, one or both of the ve calibrations is too high in the low airflow range, and low inj latency values are compensating. however, if drivability is good and fuel trims are inline, no need to mess with it.
Old Nov 3, 2010, 07:27 AM
Tbtalon94's Avatar
That's what I figured. Only thing is I'm going to have to play with the Boost range on the VE tables as my Wideband doesn't match the values in the Fuel table. It's close, but not perfect.
Old Mar 21, 2011, 08:32 AM
mrfred's Avatar
First post updated with my latest settings for these injectors.
Old Oct 23, 2011, 01:44 PM
KOOLER's Avatar
Do you happen to have any numbers for pump gas?
Old Oct 25, 2011, 02:11 AM
KOOLER's Avatar
OK, this is kinda strage b/c whatever scaling I'm using for these injectors (current one is 1218) I finally always get trim -12,5%. Higher value I put - longer it takes to climb to -12,5% but its always the same. I'm using Detschwerks 300 LPH fuel pump if it does matter.
Old Oct 25, 2011, 06:25 AM
mrfred's Avatar
the dw301 is probably overrunning the factory fpr.
Old Feb 1, 2012, 10:17 PM
PrimerSdime's Avatar
I have the same problem with my FIC 1100's/DW301/stock regulator. I'm thinking about installing an aftermarket fuel pressure regulator to see if it helps.
Quick Reply: testing the new FIC 1100 cc/min saturated injectors
