Evo VIII Ecu (USDM) in Evo IV (JDM)
Old May 10, 2010, 08:57 AM
LanEvo IV's Avatar
hi guys.... I´m from el Salvador, and I have an Evo IV...
I´m made this swap in my Evo 4, but I need the correct pinout changes for this swap (put an Evo 8 ecu (usdm) in an Evo 4)...
If somebody have the diagram of this two ecus eith the pinout changes, I will apreciate so much!! Thanx1!!!!
Old May 10, 2010, 10:48 AM
YaroRS's Avatar
have a look here https://www.evolutionm.net/forums/ev...evo-6-tme.html it's been done to evo 6th.
Old May 10, 2010, 02:32 PM
LanEvo IV's Avatar
Thank you very much!!1 I´m think that Evo IV ecu is ismilar to Evo 6 Ecu right???
almost the same pinout changes...
Old May 10, 2010, 03:32 PM
todd6027's Avatar
no slightly different
Old May 10, 2010, 04:16 PM
todd6027's Avatar
swap
pin 8 and 22
move pin 20 to 32
move pin 21 to 34
32 /34 have no pins/wires on evo4
remove (not needed)
pin 91
pin 87
run extra wire /pin to 79 for flash connector
join wires to hot cat sensor connector under drivers seat or remove bulb in dash
you will need to disable immobiliser in ecu and turn off cel for fr o2 sensor heater circuit or wire in a 4 wire o2 sensor
12 v switched to one o2 heater wire and the other heater wire to pin 60 at ecu
Old May 11, 2010, 11:01 AM
LanEvo IV's Avatar
Originally Posted by todd6027
swap
pin 8 and 22
move pin 20 to 32
move pin 21 to 34
remove (not needed)
pin 91
pin 87
Thank you very much!! I apreciate your help!! thank you!!
Old May 11, 2010, 01:04 PM
todd6027's Avatar
let me know how it works out
Old May 11, 2010, 01:07 PM
LanEvo IV's Avatar
swap
pin 8 and 22
move pin 20 to 32
move pin 21 to 34
remove (not needed)
pin 91
pin 87
All is clear only this two things:
and
12 v switched to one o2 heater wire and the other heater wire to pin 60 at ecu[/quote]
i don´t understand very well =)
Old May 11, 2010, 01:53 PM
RoadSpike's Avatar
and
i don´t understand very well =)[/QUOTE]
Pin 79:
You know that white connector on the evo 8 right next to the odbii port? Thats the wire you don't have in the evo 4 and need to run it in order to flash the rom.
Immobilzer:
Is part of the periphery on the evo 8-9 roms and you need to turn it off or the car will not start. See this url.
http://evoecu.logic.net/wiki/Periphery_Configuration
todd6027's Avatar
evo4 has a two wire o2 sensor , evo5 onwards use 4 wire heated o2 sensor so the ecu expects to see the resisitance of the heater circuit when it doesnt it will put on the check eng light . so if you use your own o2 sensor you will have to disable the heater circuit cel.
evo 4s dont have any wire or pin in for ecu pin 79 so you need to put one in there , use one of the pins you disconnected 91 or 87 then add on enough wire to go up near the obd socket , this wire you connect to the small white connector on your flash cable.
also its easier if you use use evo5 to 9 injectors 560cc stock evo 4 are 510cc
Old May 11, 2010, 02:48 PM
LanEvo IV's Avatar
thanx a lot todd6027! i aprecciate yor help!1 thank you!!! I´ll tell you hw was my swap!!!
Regards!!
Old May 11, 2010, 02:56 PM
LanEvo IV's Avatar
Originally Posted by RoadSpike
[/i][/b]
Pin 79:
Immobilzer:
http://evoecu.logic.net/wiki/Periphery_Configuration[/quote]
Thank you very much!! I´m very grateful!!
Old May 21, 2010, 08:25 AM
LanEvo IV's Avatar
Hellos friends!!!
Today, I´ll put the E8 ECU in my E4. So wish me luck.
I did not do before, because I had problems with my laptop but now not happen.
I just want to know the steps to follow ... What I have to do first and last? someone might describe them? I hope not to take away a long time. Thanks!
Old May 21, 2010, 09:19 AM
RoadSpike's Avatar
Hellos friends!!!
Step 1) Wire it in
Step 2) Flash out the immobilizer
Step 3) Test
Old May 24, 2010, 06:52 AM
LanEvo IV's Avatar
My car don´t star!!!
I think that is the inmoviliser but I try to disable but I could not.... I don´t know how =S....
when I run ecuflash I get a read image.. but i don´t find for change the periphery codes, etc... Can you help for explain best way to understand this??'
Apologize for the inconvenience!!!!
Cheers!!!
Quick Reply: Evo VIII Ecu (USDM) in Evo IV (JDM)
