TephraXMOD V1
#32
I had one picture that I was able to attach to the forum.
This is the wire used for ADC map switching. This is a White-Black Stripe wire that runs from ECU Pin 115 to the Fuel Temp Sensor harness, right on top of the fuel tank/beside the pump/etc.
The location is right by the trunk/fuel tank lever on the driver side.
I apologize for the horrid quality picture (and the gravel on the floormat), but figured it was better than nothing. If nobody comes up with a proper guide, I'll take some photos and do it properly at the end of the month.
Essentially, cut this wire and ground with a ~250 ohm resistor (I actually used 221ohm because I just had a bunch) with the failsafe on the meth kit of your choice. Follow the wiring diagrams posted by tephra in the second post. Obviously, the cut portion of wire used is the forward portion, the bit still connected to Pin 115 Make sure you use the Resistor ADC Mode, or you'll throw a CEL because the car is confused.
Are you using the AEM kit or Aquamist?
I have the AEM and am going to attempt this
#38
crazy cool just one question I have maybe I missed it but are we able to do gear based mivec for agressive spool and then in higer gear not have to combat surge or will this be a version 2 feature. Anyway great work and expect a donation when I finally get my fp green set up put together.
#42
It's version 1 for a reason.
I'm sure tephra wants a bit of a break from all this, he's put out an awesome "product". When he starts up version 2, he might add more fun things.
#43
is there anyway to tell what map your currently running? Im thinking of using this for swapping between e85 and pump. Is there some way to see what map you are on or do you just have to try to keep track in your head?
Thank you Tephra and all those that contribute so much to the community.
#45
