4G18 on ecuflash
Old Jun 23, 2010, 05:40 PM
holydevil's Avatar
4G18 on ecuflash
Hi, first of all im using Proton Waja year 2001 . I got 4G18P Mitsubishi engine inside with manual tranny. i manage download my rom using Evoscan software.
But i have cannot edit the my ecu rom. how can i edit it ?
File Type: zip
Old Jun 23, 2010, 07:25 PM
Ceddy's Avatar
You need to write a definition for it, or have someone write one.
From the file size it looks like its a SH-2 ecu.
Old Jun 23, 2010, 10:21 PM
acamus's Avatar
Location: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
here
File Type: txt
Old Jun 24, 2010, 08:23 PM
holydevil's Avatar
acamus: so i just replace the current C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\lanc er\97400004.xml with yours.
when i load the rom files
it says
[11:22:45.937] Unable to find parent metadata evo7base
[11:22:45.953] 262144 byte image read.
is this normal bro ?
Old Jun 24, 2010, 08:32 PM
holydevil's Avatar
i think its SH7? am i right ? my friend told me its SH7
Old Jun 24, 2010, 09:37 PM
acamus's Avatar
it says
Reinstall your ECUFlash, the base files shall be available in evo subdir.
Old Jul 6, 2010, 10:49 AM
nestoledo's Avatar
acamus, sorry do you have definition for these rom
File Type: zip
Old Jul 10, 2010, 11:53 PM
holydevil's Avatar
i reinstall and so on i still get
i have no idea o.o
Old Jul 12, 2010, 12:28 AM
acamus's Avatar
You should have this file
C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\ evo7base.xml
it comes with installation.
Old Jul 12, 2010, 12:29 AM
acamus's Avatar
No, but I could create one
Old Jul 13, 2010, 07:58 PM
holydevil's Avatar
ok i manage open it well
[10:54:45.046] 97400004 (20 tables) inheriting evo7base (73 tables) [10:54:45.078] 262144 byte image read.
after i put a evo7base.xml on
then it work perfectly fine thanks! hehehe. wanna see my setup now bro? can review abt it?
Old Jul 22, 2010, 06:01 AM
dollarwize's Avatar
hey, i'm having a problem with my ECU. Its the 4G18 engine and I had CVT but replaced it with a gearbox. Now it seems that i'm getting a cut in power under load...mostly in 4th and 5th gear and going up hill. I am using the same automatic ECU, i think this is the reason for the problems.
how can i fix this? its real hard to get the manual ecu where i live.
Old Aug 6, 2010, 10:05 AM
nestoledo's Avatar
thanks, can you send it to me
nestoledo@yahoo.com
Old Sep 26, 2010, 05:20 PM
beto_gt's Avatar
hi, well i used this definition acamus sent to nestoledo, and i gave a +20° and when i ran mitsulogger, there were no knocks detected, is this alright or mitsulogger is not having good comunication with the ecu??? thanks
Old Sep 26, 2010, 10:00 PM
acamus's Avatar
According to the ROM there is no Knock sensor. Does it answer your question?
Quick Reply: 4G18 on ecuflash
