Help with scaling FIC Bluemax 1450 injectors
Hey guys,
Can someone help me out with starting scaling/latency values for FIC Bluemax 1450cc? I am running 91 oct right now. After searching for a while I found these values (these are for 92 or 93 oct).
Scaling:1329
Latency:
2.784
2.112
1.680
1.368
1.176
0.984
0.816
I tried out these values and the car started but threw P0300 misfire code. I am installing my WB tomorrow for further tuning. If someone can share 91 oct starting values that would be great.
Thanks in advance.
(stock turbo, ported hotside exh mani, 3.5in FMIC, no cat, kelford 272...)
Scaling:1329
Latency:
2.784
2.112
1.680
1.368
1.176
0.984
0.816
Thanks in advance.
Its really hard to get injectors working right without a WB. Just trims will not tell you the whole story.
latency-
3.264
2.232
1.68
1.272
1.08
0.888
0.696
scaling-1271
I havent done 1450s with a MAF in a dog's age so I had to dig to come up with the scaling. The latency is good to go however.
aaron
latency-
3.264
2.232
1.68
1.272
1.08
0.888
0.696
scaling-1271
aaron
latency-
3.264
2.232
1.68
1.272
1.08
0.888
0.696
scaling-1271
aaron
latency-
3.264
2.232
1.68
1.272
1.08
0.888
0.696
scaling-1271
aaron
I will tell you though, these injectors are a PITA on pump. They need to flow A LOT to do well.
e85....they are great.
I have mine idling just fine, but I am out of fuel pump for WOT. My settings are as follows....
PUMP 93
Scaling = 1329
e85
Scaling = 1008
Latencies
2.784
2.112
1.680
1.392
1.176
0.984
0.816
Fuel trims are within 3%. Perrin intake tube, Vibrant filter, MAF, Revolver cams.
PUMP 93
Scaling = 1329
e85
Scaling = 1008
Latencies
2.784
2.112
1.680
1.392
1.176
0.984
0.816
Hey guys,
I installed the WB today and did some logging with Mitsulogger
Scaling:
1170
Latency:
3.264
2.232
1.680
1.272
1.080
0.888
0.696
FT Low +8
FT Mid -6
The cruise was a little "jerky" at some points and AFR jumped between 13-16 during these jerks
Idle was around 15.5-16
Anyone can explain this?
Any advice guys on what to do next? Im planning to increase scaling to 1218 tomorrow, but I feel that idle will be even leaner. I will probably try these latencies also:
2.784
2.112
1.680
1.392
1.176
0.984
0.816
Do I have to change latencies in order to fix idle?
Thanks for everyones help
Scaling:
1170
Latency:
3.264
2.232
1.680
1.272
1.080
0.888
0.696
FT Low +8
FT Mid -6
2.784
2.112
1.680
1.392
1.176
0.984
0.816
PUMP 93
Scaling = 1329
e85
Scaling = 1008
Latencies
2.784
2.112
1.680
1.392
1.176
0.984
0.816
PUMP 93
Scaling = 1329
e85
Scaling = 1008
Latencies
2.784
2.112
1.680
1.392
1.176
0.984
0.816
Did another log
Scaling = 1329
Latencies
2.784
2.112
1.680
1.392
1.176
0.984
0.816
Got this
FT Low +3
FT Mid -4
Idle is around 15.5 now
Any input on how to get them close to within 5%
Scaling = 1329
Latencies
2.784
2.112
1.680
1.392
1.176
0.984
0.816
Got this
FT Low +3
FT Mid -4
