Does knock cause Backfire or the other way around?
Old Sep 20, 2010, 09:44 AM
10isace's Avatar
I'm playing around with my timing (trying to get a little more advance) and after I logged a pull and let off the throttle it backfired. It was at @7700, 20 load (2 byte), 10 counts of knock. My question is did the knock register because of the backfire or is the backfire caused by the knock? Logically I can see both.
Old Sep 20, 2010, 09:48 AM
buchnerj's Avatar
In most cases the backfire is just a cause of having a pretty rich AFR. When it gets so rich and you have been beating on the car for a bit the hot exhaust and turbine assembly can ignite the rich AFR exhaust gases and lead to a backfire. 10 counts is a good bit of knock though. What were the AFRs?
doggery
Sep 12, 2015 10:41 PM
BoostinBird
May 6, 2010 06:41 PM
italianevo88
15
Oct 2, 2009 02:16 PM
xpro
Nov 6, 2007 02:34 PM
GOTMEALANCER
Lancer Troubleshooting
Jul 4, 2006 04:58 AM
Quick Reply: Does knock cause Backfire or the other way around?
