Adjusting what temp to turn the fans on
I have the EVO8 ECU in my 1G, I am running the Tephra v7 9563 rom and the only table i can find is the IC relay temp which has the on temp as 221 and the off temp at 212. What gives? I have been searching quite a bit without sucess. I want to tell the fans to come on sooner. Which table should I edit?
copy over this xml to C/Program Files/OpenEcu/rommetadata/Mitsubishi/Evo
then open your rom and in the bottom you should see thermo fan tables
