Need help. DMA does not work in Live Map.
Old Oct 7, 2011, 02:11 AM
Tomcat's Avatar
Transferred the code DMA and Mod V7 ROM 96532706 no SD and 96533706 with SD.
Did two ROM 93270019 - Lancer 9 1.6L, MAP (VE), MT, not Turbo. 256kb
80230006-Lancer 9 2.0 MAF, AT, not Turbo. 512kb.
As a result 80230006 ROM DMA and V7 in Live Map 340 runs.
In 93270019 the DMA not get in touch (read error), only in MUT.
DMA code transferred in both ROM the same way - without any changes.
Tried to flash in your ECU 96532706 96533706 and - DMA works.
But I have this ROM is not suitable for the machine.
Spread *. bin file. Rename the bin to the Zip. The file bin and idb for IDA.
I hope someone or something can help. Perhaps different algorithms for communications.
File Type: bin
Old Oct 13, 2011, 06:08 AM
Tomcat's Avatar
jcsbanks, tephra, ziad, logic, mrfred, someone who can. I need Help!!!
Look at the archive with the ROM and IDB file for IDA.
Where the error? Live MAP reset dead doing. On MUT running. BUT the DMA read request error!
Tell me where to look? And because of what it might be?
Old Oct 13, 2011, 02:46 PM
ziad's Avatar
mate i dont understand assembly, try donner. he is very good with it.
usually with dma read request error. u have either the dma code not working, or mut table not setup properly.
Old Oct 13, 2011, 10:34 PM
Tomcat's Avatar
Reset DEAD works. By MUT logging goes. Error in the DMA, where the block reading or even in any communications. There is no switching
with MUT to DMA.
Transferred to the DMA code + Tephra Mod V7 96532706 with no SD.
As a result, 2,0 AT (MAF) is working.
And I have a 1,6 MT (MAP) does not work.
DMA did not change the code.
Old Feb 15, 2015, 10:49 AM
kx151m's Avatar
you can share the result 80230006-Lancer 9 2.0?
Old Feb 22, 2015, 09:26 AM
burgers22's Avatar
How did you "transfer" the code? The internal references between two different ROMs can vary hugely. You can't just copy paste.
sebass007
Lancer How Tos / Installations
40
Dec 28, 2020 08:20 AM
mrfred
May 1, 2020 10:16 AM
br3akrboi
Dec 6, 2015 11:40 AM
dingus
Jul 10, 2015 08:42 PM
upstateEVO
Jan 9, 2012 12:32 PM
Quick Reply: Need help. DMA does not work in Live Map.
