O2 Sim patch 88840016, 88840017
Old Mar 7, 2012, 07:49 PM
Eugeny dontknow's Avatar
Its original source https://www.evolutionm.net/forums/5353216-post148.html , i modifed mrfred O2 Sim patch.
Also, many thanks l2r99gst for his posts with the analysis of work procedures.
If you want to modify this patch for your other rom then you need to look at these requests in their mut table and substitute them
in the code subroutine decrement the value to 1, then find the address of the symbol the hook (I'm looking for E4 D5 08, 4th byte
may be different then, all as more have mrfred except the last two bytes).
FFFF 6A64 request 13 (front O2)
FFFF 6B36 request 1C (load160)
FFFF 6A68 request 3C (rear O2)*
flash it.
my carman scan lite reed the rear o2 voltage from 0.136 to 0.43 V
File Type: xml
Old Mar 30, 2012, 08:17 AM
three week without cel
Old Apr 1, 2012, 09:59 AM
benderrodriguez's Avatar
Love this thank you!!!!!
Old Apr 2, 2012, 02:39 AM
enjoy ride)))
Old May 14, 2012, 07:20 AM
HaVoC187's Avatar
Can someone give me a step by step on how to apply this patch to my rom (88840016) because I don't understand any of this?
Old May 15, 2012, 03:14 AM
Read carefully the first post, this recompilation code mrfred here at this link https://www.evolutionm.net/forums/5353216-post148.html
Old May 16, 2012, 09:59 AM
it's sample for dummys))) all need mod for disable rear o2, but I recall that I experimented with 88840017 and 88840016 in the archive, and may require correction of addresses.
http://flashmirrors.com/files/y0ujl0...cf/Desktop.rar or http://narod.ru/disk/50268473001.851...sktop.rar.html
Old May 23, 2012, 08:41 AM
change adress for heater cel 88840016
Old Dec 5, 2021, 03:40 AM
mirko's Avatar
Hello, I have 88840017 evo 9 edm rom. This rom is already tuned by an unknow tuner shop. I save my rom with ecuflash on my pc desktop (hex file). Is possible to apply this patch in this saved rom? I add all the line in the xml present in ecuflash folder, when I open ecuflash and I choose the hex file that I saved I see the new option on the left index. Is correct? Can I proceed with the programming ecu on car? Can you help me?
thanks
Old Dec 6, 2021, 01:24 AM
mirko's Avatar
It's correct this xml definition for 88840017?
<table name="Rear 02 Sim Hook" category="Rear_02" address="c1e4" type="3D" level="1" scaling="Hex16">
<table name="Code" type="Static X Axis" elements="1" scaling="Hex16">
<data>Hex16</data>
</table>
<table name="Address" type="Static Y Axis" elements="10">
<data>C1e4</data>
<data>C1e6</data>
<data>C1e8</data>
<data>C1ea</data>
<data>C1ec</data>
<data>C1ee</data>
<data>C1f0</data>
<data>C1f2</data>
<data>C1f4</data>
<data>C1f6</data>
</table>
</table>
<table name="Rear 02 Sim Subroutine" category="Rear_02" address="4a000" type="3D" level="1" scaling="Hex16">
<data>Hex16</data>
</table>
<table name="Address" type="Static Y Axis" elements="20">
<data>4A000</data>
<data>4A002</data>
<data>4A004</data>
<data>4A006</data>
<data>4A008</data>
<data>4A00A</data>
<data>4A00C</data>
<data>4A00E</data>
<data>4A010</data>
<data>4A012</data>
<data>4A014</data>
<data>4A016</data>
<data>4A018</data>
<data>4A01A</data>
<data>4A01C</data>
<data>4A01E</data>
<data>4A020</data>
<data>4A022</data>
<data>4A024</data>
<data>4A026</data>
</table>
</table>
<table name="Heater CEL" category="Rear O2" address="2EF6B" type="2D" level="2" scaling="blobbits">
<table name="Bit values" type="Static Y Axis" flipy="true" elements="8">
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>Rear O2 Heater CEL Enable</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
</table>
</table>
Old Dec 6, 2021, 07:34 AM
Dow Jhob's Avatar
yes
ps. read first post (you need to look deeper down the rabbit hole)
Old Dec 6, 2021, 07:40 AM
mirko's Avatar
Originally Posted by Dow Jhob
yes
Thanks, this ecuflash table values are correct related the definition?
O2 Sim Hook data
0009
0009
0009
D002
400B
0009
A002
0009
0004
A000
O2 Sim SubRoutine data
DA06
6AA1
6AAD
4A09
DB05
6BB1
6BBD
4B09
4B01
3ABC
DB03
2BA1
000B
0009
FFFF
6A44
FFFF
6B16
FFFF
6A48
Old Dec 6, 2021, 08:48 AM
Dow Jhob's Avatar
O2 Sim Hook data
0009
0009
0009
D002
400B
0009
A002
0009
0004
A000
DA06
6AA1
6AAD
4A09
DB05
6BB1
6BBD
4B09
4B01
3ABC
DB03
2BA1
000B
0009
FFFF
6A44
FFFF
6B16
FFFF
6A48
yes
use attach
File Type: xml
Last edited by Dow Jhob; Dec 6, 2021 at 11:39 PM. Reason: stupid forum corrupt long string
Old Dec 6, 2021, 11:23 PM
mirko's Avatar
yes
use attach
Thanks, can you check if in the Ecuflash print screen is correct? Excuse me, but this is the first time that I try to "play" with Ecuflash.
Old Dec 6, 2021, 11:33 PM
in general everything is correct but use attach from my prev post
Quick Reply: O2 Sim patch 88840016, 88840017
