FreeFuel ECU patch - a flex fuel implementation to Evo ECU
Old Sep 16, 2014, 04:49 AM
  #256
dr_latino999's Avatar
Originally Posted by tscompusa
Very soon. Its going to be going into my evo 8. It wont be to much longer before we have a finished product available to public. Its not just a rom either, its hardware also. The hardware is very cool and will be priced very well also.
Sweet, as long as the hardware / sensor comes with the provisions to tie into -AN lines count me in when I get back to the states.
Old Sep 16, 2014, 11:55 AM
  #257
wtftuck's Avatar
Will this require a new e85/91 tune or can it be adapted to a Tephra mod tune?
Old Sep 16, 2014, 06:48 PM
  #258
CDrinkH2O's Avatar
You adapt your existing V7 Tephra tune. No need to retune.
Old Sep 17, 2014, 07:17 AM
  #259
tscompusa's Avatar
It definitely needs tuned. You can take your base e85 tune and base 93 tune or whatever you use, but then the tables need blended properly. Our system has a bunch of blender tables. Its just like AEM's setup.
The tune session would involve the person going from say e85 to e70 to e60 to e50 to e40 to e30 to e20 and whatever their local straight fuel is.
The hardware has the ability to log everything evoscan can, so its pretty awesome.
As far as sensors go, the GM sensor works fine. And you can get the connectors that push on the ends and they certainly make AN push on connectors for it.
Old Sep 17, 2014, 07:24 AM
  #260
CDrinkH2O's Avatar
Old Oct 19, 2014, 09:20 AM
  #261
2006IXWW's Avatar
tscompusa..... any update on the true flexfuel rom for a Evo IX running stock ecu?
Old Oct 20, 2014, 09:57 PM
  #262
tscompusa's Avatar
Its here. I'll get pics of the display lit up. I'm gonna wire it to the battery direct temporary to display what we have here.
It can log everything evoscan can, plus custom stuff. The box is quite nice. It reads eth percent, fuel temp, etc etc.
Old Oct 24, 2014, 01:21 AM
  #263
I'll be back for the Holidays and redoing my fuel system, I look forward to this being ready for an VIII application. Hell, I'd even guinea pig it
Old Oct 28, 2014, 12:06 PM
  #264
GravityKnight's Avatar
What size quick connect o-ring fittings are on the sensors?
Has anyone patched 94171715? (SD, Omni, v7, mods etc.)
This would be the ultimate setup, I live 30 miles from E85 and was going to avoid it on this build (was a pain being that far from a station). But this would allow for the ocassional fill up/fun
Amazing work by all involved.
Old Oct 28, 2014, 04:52 PM
  #265
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
The conti flex fuel sensor is 3/8" SAE
Russell 644123 -6AN Male to 3/8" SAE Fitting
I would recommend the above quick-connect fitting over the plastic clip version.
You can see the recommended fittings installed on the smaller conti sensor in the photo of mine here:
Old Oct 28, 2014, 05:44 PM
  #266
^^^ Thanks for the info!
Looks good!
Old Nov 20, 2014, 08:48 PM
  #267
sssr20det510's Avatar
Bump any updates for the ix
Old Dec 16, 2014, 02:13 AM
  #268
thebluesky's Avatar
So, any long term updates from those using the patch yet?
Old Dec 16, 2014, 01:22 PM
  #269
CDrinkH2O's Avatar
I've been running the 9653E706 patch with my homebuilt ECA for the past 11 months. It works so well I no longer have to think about whether I fill up with 91 or E85. The only advice I can offer to anyone thinking of doing this is....what are you waiting for?
Old Dec 19, 2014, 09:59 AM
  #270
prowakeskater's Avatar
guess Ill have to get on this
Quick Reply: FreeFuel ECU patch - a flex fuel implementation to Evo ECU
