speedometer input/ tachometer output
I am wondering if the speedometer input and/or tachometer outputs can be changed in the stock ecu? Can someone make an .xml patch to make them changed?
I will start from the beginning. Chassis is a Lexus IS300, engine is a 4g63, transmission is a t56. I am wanting everything to work in sync with a stock evo8 ecu, without multiple additional boxes.
First is the speedometer input. I can choose between a lexus ABS wheel speed sensor, or a GTO transmission speed sensor as an input for the evo ecu. I am worried that the speed will either be too low, and the car has to be rolling 30mph to get out of a stationary rev-limit, or when the car is actually going 80mph, it is hitting speed cut. I am wondering if I could calibrate the input to be close enough so that the ecu is happy at all times, while maintaining all functionality. I am sure I could do this with a speedohealer(little box #1)
Second is the tachometer output. The lexus came with a 6cyl. engine, so I would love to change the tach output to match the oem tachometer. I know this can be fixed with a tch-adapter(little box #2)
Third is a potential speedometer output. I am wondering/hoping that an unused output (fpr sol, or even boost sol in my case) could be changed to become a user-calibrated speedometer output. That way I could have the ecu receive its correct speedometer signal, then output a different signal so that the cluster will register correctly. This would need the most "end user" treatment to get right. I know that this could be done with a speedohealer(little box #3)
I understand making .xml patches takes time, and I am asking for something one-off. That's why I am offering "donatins", as well as "retail" space on the side of the car to someone that could make this happen. PM me any specifics
Thank you in advance,
Justin
Justin
SuperHatch
Jan 10, 2007 10:58 AM
