AFR wierd issue.
One other note on the 9653 ROM is that it uses up to three different load variables for fueling... make sure you are logging the correct load variable, iirc it has to do with coolant temp when it switches variables. You may think you are looking at the correct load value and it is reading at a different cell...
George
To answer Foxbat...It is located in the "Important ECUflash thread" in the sticky at the top of the page when you enter the ECUFLash forum
George
One last thought Biggy VIII, move to closed loop and see what your fuel trims are? also have you scaled your MAF? I had a 9653 conversion I did that I had to rescale the MAF afterward to correct idle fuel...
https://www.evolutionm.net/forums/ec...-maf-pics.html
Raceghost
Feb 11, 2017 10:27 PM
