EcuFlash Tunning Map Suggestions
Figure I'll Post up on this forum since I have an evo as well...
Hello All,
First off its a mix of Mitsu parts but its all working together nicely. I have ceddy mods flashed to a 99 eclipse ecu and wired up to my 1997 AWD Dohc 16G Turbo Galant. I managed to tackle all of the emission problems and do not have any cell lights at idle...
So iam seeing up to 4 counts of knock as the engine starts to build boost.
1. I believe I should richen the afr in the map to decrease knock. from about 10.2 to 10.5 at around "3600rpm/210load" Is that a good idea?
2. Should I adjust timing at all? What happens in the log that tells me to increase or decrease timing?
My High Octane Ecu Map.
And here is a sample of the last log I took running this map. I let off at 4100rpm because I have cell on knock active and was worried of problems. I also noticed the tps isn't reading 100 which will need to be fixed later as well.
Again, Iam new at this so the more help the better.
Hello All,
Well I didn't even modify any of the ignition map settings.
This is what I was running on the above log.
Iam thinking of changing to the following new modifications..
Fuel Map
Ignition Map " I changed the Load Values to match up a little better and correct the last field for rpm.
Fuel Map
digitalightkenz
Apr 9, 2018 10:43 AM
