Possibly the worst tune I've seen.
O_O ...... seriously you pulled these from running cars? that 2nd to last is just not believable. I mean damn even if you werent that knowledgable. At some point you would itleast STUMBLE over some type of information related to tuning... like to even download ECU flash, or even knowing what a XML definition file is. You would pick up SOME knowledge.
I've got maps on my computer from reputable tuners for evos that would blow your mind. You probably wouldn't even believe me who made them if I told you. I see so much stuff its unreal.
That's one thing I can say, you wont EVER see in your lifetime an unsmooth map from me ever.
Btw just for humor, heres a map my one customer thought was ok to run his car with. This was from back in 2011 I believe hahahaa. This is the worst one ive got probably in regards to functionality. This would melt the engine down.
And the fuel map he made along with it:
Tuxevo-
Was the car on pumpgas or is it still or was this E85? I may have missed it but what boost is 327 load in this particular setup? With SD everything can end up variable so while your timing curve sounds right, 2* up to 15*, its all relative to everything else.
