1byte load goes to 0 above 4k
car in question is a 99 gsx. stock black box ecu running ceddymods big maps. 2.3L. Hx35. 3" Gm maf w/ translator.
once it hits around 303 load it drops to 10-30 load and once it goes down to 306 it normalizes. Has anyone ever seen something like this happen? I can understand if it ran out of map but theres still a good bit left. I've also tried tuning at the location it drops to but it refuses to respond and still drops to 9afr
Change "2byte to 1byte Load Factor" to higher number in your rom and in evoscan Load 1byte formula...
Default is 1.2, try setting it to 1.3 or 1.4.
I use 1.4 on my car:
that option isn't in the dsm files. But I'm currently good until 340 load. It shouldn't be limiting it to 300. I did some reading and found out that ecu load is limited by the maf. It's still set up for a stock maf which is 289. That might also explain why I had to scale my 1050's as 1100's. I'll try it this weekend when I get back.
What max load does 1.4 put you at?
I believe its ~360load max with 1.4 factor.
