problem with load commanded vs/actual
here is where I am at.
I have done the Tephra mod version 7 with SD.
The car starts and idles perfect.
14.7-15.2 AFR with no knock. so I did something right......
I have done the big map conversion to timing, fuel etc... load 0-380
however here is what I notice today when I finally went to drive the vehicle and log.
While logging live it will show values that spread across all cells. 0-300load.
But when I review the log once it save. It will only show a load value up to 160.
Also it appears that it coincides with the same cells in the tune.
How come my pcm isn't using the full map?
I guess the best question would be. What ratio is the best for getting you close to using the 0-380 map. IE 2byte to 1byte load set at 1.2? 1.4? 1.8? 2.0?
cuscoevo
May 24, 2010 10:44 AM
