Can't get 94170715 Speed Density ROM to start.
Old Jan 24, 2015, 09:06 PM
okevolutionVIII's Avatar
I copied everything over from my MAFS 94170715 map that runs great and used a Spoolin' Up SD harness to plug the OEM MAFS plug into the AIT sensor in the UICP and the GM-style 4-bar MAP sensor I've been using. Installed a Tial BOV and filter straight to the turbo.
The engine will start up, revs jump up as usual and then drops right back to 0 so it doesn't even hold an idle. This is the "Phenom SD Fix" ROM so is there anything I might be missing?
Old Jan 25, 2015, 07:51 PM
Bump. Does the OEM plug for the MAP sensor stay unplugged while the Spoolin' Harness takes over? Not sure what I'm missing here.
Old Jan 28, 2015, 06:57 PM
Ttt
Old Jan 29, 2015, 05:50 AM
jeffbeagley's Avatar
I'd swap over to the 9653 since IIRC it's more defined.
Post up some logs of everything plus IACV Position in steps or % and IACV trim.
Old Jan 30, 2015, 11:16 PM
I downloaded the 9653 SD ROM a few days ago and started copying everything over, won't get to try until next week as I'm out of town. Just wondering what simple thing I could be over looking as it's my first try at SD. If I can get the car to start and idle then I should have not problems from there.
Old Feb 1, 2015, 07:58 AM
SiriusEvo's Avatar
How do you have your connection for the Map sensor? Are you logging in Evoscan, check to see that Map sensor is reading correctly first off and that it is scaled properly in your rom
Raceghost
Nov 23, 2016 10:17 PM
GeneralDisorder
Nov 23, 2016 01:32 PM
HornstarBU
Mar 24, 2015 02:25 PM
EvoIXPilot
Mar 19, 2015 09:30 PM
Quick Reply: Can't get 94170715 Speed Density ROM to start.
