Which load for boost tables?
So I'm running the Tephra V7 version of 90550001 (90550701) and I've figured out that my ECU is using 2 byte temp + baro + IAT compensated load. So it's actually hitting load cells in the timing map that are 20 less than the 1-byte load that I was previously using.
Now my question is are the load targets in the Boost Desired Engine Load (BDEL) table and the Boost Cut Load also based off this compensated 2-byte load or is it 1-byte load?
I suspect its the 2-byte but everyone has said to use 1-byte on Tephra roms so i just want to be sure because my timing is following 2-byte compensated.
wfochris
Dec 22, 2009 10:33 AM
razorlab
Jan 5, 2009 06:20 AM
razorlab
Dec 1, 2008 10:00 AM
