Barely runs after cold starts, runs great once it warms up.
So today after I started it I had to use the gas pedal to keep it running so it was hard to tell you the exact AFR's. However after a minute or two I was able to let of the gas without it shutting off and at idle it was very lean, 17:1 to off the gauge. Again, once it warms up it runs and idles great. Any ideas Todd or anyone else? It's Tephra V7.
Increase the values in the MAF Comp vs Coolant temp tables about 10% for temps 122 and below. There 2 of these tables, they are redundant, make sure you change both. Start there and increase as needed. This is what makes my car driveable when cold, it was doing exactly what yours is doing, except not as bad..
I did a boost leak test today starting at the intake manifold up to about 21 psi and all was good. Now that that section is good I will need to do it again but from the turbo inlet.
aahmes57
Lancer Troubleshooting
Apr 3, 2018 06:19 AM
