Barely runs after cold starts, runs great once it warms up.
Old Feb 27, 2015, 11:41 AM
9!'clipseDOHC's Avatar
I have an issue on my Evo V (with an Evo VIII ECU) where after a cold start it idles low (below 750) and bucks/sputters/hesitates if you try to drive it before it warms up for a few minutes. Once it warms up it runs great. I had this same map (it's a tephra v7) on my last Evo VIII and it would do the same thing, so I think it has something to do with the tune. Is there anything I can adjust to fix this?
Stock engine, turbo, etc. 91 octane.
Old Feb 27, 2015, 11:48 AM
kaj
kaj's Avatar
is your IACV working properly?
Old Feb 27, 2015, 12:20 PM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
What are your AFR's when its doing this? Is the car in closed or open loop when it does this?
Old Feb 27, 2015, 01:10 PM
kaj
kaj's Avatar
also, if tuned, you could check your cold start enrichment tables.
Old Feb 27, 2015, 02:08 PM
I just started driving the car this week so I haven't done much diagnostics yet. Because my old VIII did the same thing, with the same map, my first thought was map. I will check the mechanical things as well.
I will start it up later in the evening or in the morning and report back with both.
It is a tuned ROM, actually it was tuned by Boosted Tuning, that I had on my VIII. When I turn the key it fires up instantly when the engine is cold. It does take a few cranks after the engine is warmed up. I have messed with the cold start enrichment tables on the E85 side of the map (it's a dual map) back when it was on my VIII because it used to take a lot of cranking to start. Should that affect it once it running or just while cranking?
Old Feb 27, 2015, 02:12 PM
kaj
kaj's Avatar
wait, so it starts fine when cold, but harder when warm?
Old Feb 27, 2015, 02:25 PM
That is correct. Cold start it's running on the first crank, but isn't even drivable. Warm start it cranks for a few seconds and then fires up and runs great. This is 91 octane.
Old Feb 27, 2015, 02:27 PM
kaj
kaj's Avatar
oooh. disregard my previous statements LOL. i had this issue and Jay was able to fix it. but it was a while back and i can't remember what the issue was...
Old Feb 27, 2015, 02:57 PM
Justnii's Avatar
Cold start crappy
Bump, looking for a table fix.
This seems to happen when running SD also. The car is in Open Loops at cold temps. Do we look at adjusting the high octane map for open loop?
Old Feb 27, 2015, 03:13 PM
todd6027's Avatar
post primer enrich decay - try raise it
i went from this
1.5 1.43 1.37 1.30 1.08 1.05 1.03 1.00 1.00
to this
1.5 1.43 1.38 1.33 1.28 1.14 1.12 1.08 1.05
Old Feb 27, 2015, 03:21 PM
Justnii's Avatar
Thanks are you referring to the Load Accel IPW Enrichment - Decay Rate? This is a 10.
i went from this
to this
Old Feb 28, 2015, 01:27 PM
todd6027's Avatar
which rom are you using ??
Old Feb 28, 2015, 05:40 PM
So today after I started it I had to use the gas pedal to keep it running so it was hard to tell you the exact AFR's. However after a minute or two I was able to let of the gas without it shutting off and at idle it was very lean, 17:1 to off the gauge. Again, once it warms up it runs and idles great. Any ideas Todd or anyone else? It's Tephra V7.
Old Mar 1, 2015, 12:39 PM
kaj
kaj's Avatar
You can also check for a vacuum leak
Old Mar 1, 2015, 11:36 PM
Justnii's Avatar
Using 52680015
Quick Reply: Barely runs after cold starts, runs great once it warms up.
