Flex Fuel testing in TephraXMOD V3
Old Nov 9, 2016, 07:07 AM
  #241
asianzt's Avatar
Originally Posted by stocker77
Hi guys, I know this isn't the install section, but searched and can't find anything conclusive.
I am finally getting around to installing my Zeitronix ECA, so I can tune for E85.
I used Tephra's install directions for the ECA analog signal to tap into the fuel tank differential pressure sensor, but want to make sure I have the right harness and wire.
Anyone have a picture or can confirm that I have the correct wire harness under the dash?
Also, am I just tapping into the fuel tank diff pressure sensor wire or am I disconnecting the sensor like installing a wideband O2 in the place of the stock rear O2?
*edit* I decided to tap into the brown wire of the fuel tank pressure sensor at the fuel tank for two reasons. 1)100% sure it was the correct wire 2) the wire harness under the dash was so cramped.
David was also kind enough to confirm that I needed to terminate the sensor wire from the sensor before connecting the ECA ethanol % analog signal wire.
Thanks!
Left front driver's side harness has the blue marker and the brown wire in the center. The harness is to the left of the clutch pedal pivot in the picture.
Pretty much went through the same thought process when I went to wire my Zeitronix ECA for flex fuel. Using a Bosch style connector made it plug-n-play for the fuel tank pressure plug.
Afterwards, I decided to rewire my sensor so that it didn't cut out during cranking. Functionally, it was never an issue starting up but the CEL will flash a few times after starts to indicate that the E% has deviated too far. Using an adjustable timer-type relay resolved this "issue" for me.
I'm still battling the usual cold start issues right now.
stocker77 (Nov 10, 2016)
Old Dec 8, 2016, 12:51 PM
  #242
Tagesson's Avatar
Fuel Pressure P0455
Hello!
I have used V3 for about 2 weeks now and today came fault code P0455 (Fuel pressure) as i using this for flexconverter (komplett kit) AUDM
I know i read about this somewhere how to fix this. Anyone who knows?
I know that Tephra are busy so would rather not send emails to him if the answer is here!
Thanks!
Old Dec 8, 2016, 12:54 PM
  #243
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
Originally Posted by Tagesson
Hello!
Thanks!
Scroll down to the bottom of this page: http://www.tephra.it/v3/
Tagesson (Dec 8, 2016)
Old Dec 8, 2016, 12:56 PM
  #244
Tagesson's Avatar
Sorry! It was to easy to find
Thanks!
Old Dec 8, 2016, 01:08 PM
  #245
Tagesson's Avatar
Any fast guide how to install the XML file?
I guess it is not as easy as XMOD3?
I guess I'll keep it under rommdata> Mitsubishi> Evo like XMOD but how do i get the XML fragment to a XML document?
Thanks!
Old Dec 8, 2016, 02:29 PM
  #246
tephra's Avatar
just edit the V3 xml in notepad, and paste that XML fragment BEFORE the </rom> at the end.
then save it (if you get a privileges error/message then save it somewhere else, then copy the file back in and overwrite it)..
then just make the change in EcuFlash (to disable P0455)
Old Dec 8, 2016, 09:59 PM
  #247
Tagesson's Avatar
Thanks Tephra! Just what i needed
Old Dec 11, 2016, 09:54 AM
  #248
Tagesson's Avatar
One more question? When the XML is in Place and the P0455 i visible under MISC when i open the P0455 window i shows 1250 units is this correct?
Old Dec 11, 2016, 02:38 PM
  #249
tephra's Avatar
that doesn't seem right, the stock value should be 1594
did you grab the correct XML fragment for your ROMID?
Old Dec 11, 2016, 10:12 PM
  #250
Tagesson's Avatar
Hi Tephra!
I had probably managed to pick the wrong XML now it is 1594
should it be so, or raise it to 7969?
Old Dec 11, 2016, 10:17 PM
  #251
tephra's Avatar
Hi Tephra!
raise it
Old Dec 11, 2016, 10:38 PM
  #252
Tagesson's Avatar
raise it
OK! Thanks!
Old Dec 16, 2016, 11:55 AM
  #253
Angeltownracing's Avatar
Hi Tephra
Sorry to be off topic. Have payed for V3 two month ago via Paypal. Sent you several Mails and tried to contact you here via PM. Please, please check your messages.
Thank you.
Old Dec 16, 2016, 04:14 PM
  #254
tephra's Avatar
really?
i dont have anything, can you email me <myforumnickname> @ gmail.com
thx
Old Dec 19, 2016, 05:11 AM
  #255
tephra's Avatar
Originally Posted by Angeltownracing
Hi Tephra
Thank you.
Still nothing.. ??
Quick Reply: Flex Fuel testing in TephraXMOD V3
