Live map and speed density for 90550701
Old Mar 18, 2016, 07:21 AM
saadme's Avatar
Hey everyone
Long time lurker, first time poster!
I have a JDM Evo 7, with Tephra 90550701. I'm interested in going MAFless, and also interested in seeing the live map, if it exists. I assume live map makes it a lot easier to tune?
Can anyone help me with the ROM and XML for these?
Can someone also post a link on how to copy a tune from MAF to speed density? I assume you copy most of the tables across, and there is a conversion for some other ones?
I have a JDM evo 7 which has a MAP sensor - do I simply replace this with an Evo 9 3 bar sensor to enable SD, along with the appropriate ROM, or do I need to get something like a GM MAP sensor?
I gather I need an IAT sensor too. Turns out my car already has one, screwed into the upper intercooler pipe, dangling there, from several owners ago. Which pins do I connect this to?
Finally, is it possible to get a closed loop AFR control? What input would I wire a wideband O2 into? And what input to I wire the MAP sensor into?
Really enjoying learning this whole new world of ECU tuning!
Thanks!
Old Oct 29, 2016, 07:48 PM
danfalcas's Avatar
Looking for it also!
Old Nov 10, 2016, 06:27 PM
dom4g63's Avatar
simple task,
I also have a evo 7 , similar to you guys. I used my Omni 4 bar and plugged it directly worked in the factory location and plug.
as for the iat wire that into your maf plug same wiring as any other evo 8 or 9.
and lastly for ROM , use any evo 8 sd rom, takes some technique and patience, I have tried all with success. just wanted to know know which is better for me .
when you get to that stage you can PM me and ill assist best I can
ej20tnz (Jan 1, 2017)
mr evo7
Oct 30, 2016 03:17 PM
unihappytime
Sep 28, 2015 02:02 PM
mr evo7
Sep 20, 2015 12:31 PM
06EvoIXmr07
Nov 3, 2010 10:45 AM
jcsbanks
Feb 4, 2010 04:57 PM
Quick Reply: Live map and speed density for 90550701
