Help with tuning please
Sometimes just looking at the average AFR of cells in EvoScan is misleading because it has full lean values averaged in from when you let off the throttle. 18.4 or whatever depending on wideband. That skews the average. You can remove those values from the CSV log file in Excel before looking in EvoScan if it's a problem. That's really over complicating the process though.
Ok here are the logs, maps, and dyno sheets. have a look. nothing changed between the fuel and ignition maps just the lean spool enabled and disabled.
nlp187
Jul 8, 2012 10:32 PM
DIDYSIS
May 9, 2009 04:30 PM
