Max total upward wgdc correction vs tps table issue
I am running V7 rom 88950715, when I try to correct my tps scaling(shown on left) to match the values shown on right the car will not start. I tried redownloading the rom file and got the same issue. Any thoughts?
-David
-David
tenney (May 1, 2016)
<table name="Max Total Upward WGDC Correction vs TPS" category="Global Boost Control Settings" address="3f10" type="2D" scaling="OffsetWGDC">
<table name="TPS" type="Y Axis" elements="9" scaling="ThrottlePercentage"/>
This table has good scaling:
<table name="TPS WGDC Correction" category="Global Boost Control Settings" address="51304" type="2D" scaling="Percent255">
<table name="Throttle" address="512ee" type="Y Axis" elements="6" scaling="ThrottlePercentage"/>
</table>
Is it just missing the address?
So would the below be correct?
<table name="TPS" address="7284" type="Y Axis" elements="9" scaling="ThrottlePercentage"/>
Thanks,
David
</table>
Thanks,
David
Rando bump of this thread. I made the same mistake as OP and it basically made my car so it would start right after a flash but about an hour later it wouldnt start. All stemmed from manually changing TPS values in the table when it was gibberish.
Weird symptoms, If you key-on, CEL would not turn off after 20sec. And OBD2 scanner or EvoScan could not connect. But it ECU can still be reflashed.
Adding "address="7284"" to the table def below fixed it for me as well.
"<table name="Max Total Upward WGDC Correction vs TPS" category="Global Boost Control Settings" address="3f10" type="2D" scaling="OffsetWGDC">
</table>
</table>
PIE-R
Aug 25, 2020 07:33 PM
Mad_SB
Sep 30, 2011 08:57 AM
