Introducing the Spark Cut patch, finally a solution for SST Boost of the line
Old Aug 15, 2016, 08:18 PM
  #31
franzcars's Avatar
The patch has offically been released, Check the first post for infromation as well as the download info!
JP3NS (Aug 16, 2016)
Old Aug 16, 2016, 05:50 AM
  #32
Rado_93's Avatar
You sir are a gentleman and a scholar. Looking forward to the V1 SST to finish up testing and be released. Donation will definitely be coming your way good sir! The X platform just keeps getting better!
Old Aug 16, 2016, 06:16 AM
  #33
HatrixMouse's Avatar
Agreed!
Waiting for support for the 2012 USDM GSR. I'd love to volunteer to test, but I wouldn't want to mess anything up.
Edit: I think it's 58010005? (Taken from GoldenEvo)
Old Aug 16, 2016, 06:33 AM
  #34
jakgal04's Avatar
Does this need any changes to the tune? Timing or fueling adjustments?
Old Aug 16, 2016, 06:58 AM
  #35
franzcars's Avatar
It depends on how much boost you want, if you're fine with 3-8 psi depending on your turbo then no additional tuning, just turn it on and set the stationary rpm!
Old Aug 17, 2016, 06:39 PM
  #36
GP148's Avatar
Can confirm that 56920008 sst has been tested and works great. Stock setting gives you about 6psi. Great work 😄
Old Aug 17, 2016, 07:37 PM
  #37
franzcars's Avatar
Sweet! If you ever get a video of it launching I'd love to see it!
Old Aug 17, 2016, 11:35 PM
  #38
AndyM's Avatar
awesome work!
Old Aug 18, 2016, 01:13 AM
  #39
GP148's Avatar
I'll see what I can do
Old Aug 18, 2016, 09:28 AM
  #40
franzcars's Avatar
56920008 2011 EDM SST has been released, will continue to update the original post as tests come in successful
EvoXEmma (Aug 20, 2016)
Old Aug 18, 2016, 10:22 AM
  #41
Good stuff to hear! I can certainly test out for the 2012 GSR if needed. Since Chet did my tune (and he had a hand in helping you figure out stuff), I'll ask him to send a map as a tester.
Love your work. Keep it up!
Old Aug 18, 2016, 10:37 AM
  #42
franzcars's Avatar
Love you work. Keep it up!
I actually have someone testing bit now, so should be out by the weekend hopefully! Then we can pair up with Chet and get you set up
Edit: Actually it was tested today,so it's now uploaded on the first post along with 52680022 2008 USDM GSR , 58010005 2012 USDM GSR and 55580005 2010 USDM MR
Old Aug 18, 2016, 04:28 PM
  #43
Rado_93's Avatar
This patch is the truth! Without the launch maps you're still building ~4-7 psi out the gate and with the launch maps you're in double digits in a split second. It's really nice to get out of the hole quickly. Customers love it Franz!!! Will get some videos up in a bit so people can see it does work quite nicely. Donation was sent earlier. Really appreciate all of the hard work!
Old Aug 18, 2016, 04:31 PM
  #44
franzcars's Avatar
Thanks again! I cant wait to see videos of it, hopefully this finally gives the SST the push they need to set new records!
Old Aug 20, 2016, 07:19 PM
  #45
Mark1si's Avatar
Works good on 09 Ralliart. 4# launch
Quick Reply: Introducing the Spark Cut patch, finally a solution for SST Boost of the line
