p0141 impossible to clear
Old Sep 21, 2016, 01:08 PM
besk's Avatar
hi i have the tephra rom 88583714 on my evo9.I cant clear the rear o2 error code
i tried all way to clear the engine error code but isn't working:
on tephra mods "enable rear o2 simulator"
changed periphery2 into 89D9
could be a rom issue?
thanks
Old Sep 27, 2016, 09:18 AM
besk's Avatar
nobody ?
I found this table what work on 88580714 and 88580014.I would like to add it to my rom and try if work but I dont know which xml file modify and how to copy paste it into..
<table name="Heater CEL" category="Rear O2" address="2E9F1" type="2D" level="2" scaling="blobbits">
<table name="Bit values" type="Static Y Axis" flipy="true" elements="8">
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>Rear Heater CEL Enable</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
</table>
</table>
thank you
Old Sep 28, 2016, 06:23 PM
JKX
JKX's Avatar
you have to find the periphery bit and disable it
Old Sep 28, 2016, 06:25 PM
JKX
JKX's Avatar
Also look at the last post here: https://www.evolutionm.net/forums/ec...d-you-use.html
Old Jan 16, 2017, 12:56 PM
besk's Avatar
EDIT
ok I did it adding the new part on the XML
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
</table>
</table>
In tephramods I enabled ( 1 ) "Flash CEL on Knock "
will be still working after the changing the Rear Heater CEL Enable?
thanks
Old Jan 21, 2017, 04:52 AM
besk's Avatar
bump
Old Jan 23, 2017, 01:05 PM
todd6027's Avatar
yes it will , you only disable the cel for the rear o2 heater
besk (Jan 24, 2017)
TonyG
Sep 16, 2007 07:09 PM
onboost
Jun 22, 2007 02:41 PM
mk4killer
Sep 13, 2004 01:36 PM
SilverEvo8owner
Apr 19, 2004 01:38 PM
Quick Reply: p0141 impossible to clear
