Per cylinder fuel trim
Old Sep 26, 2016, 08:19 AM
pisyakot's Avatar
Hi guys! Sorry for my English.
Now I'm testing a per cylinder correction of the mixture. At the moment I only have one wideband sensor. Therefore, it was decided to use the EGT sensor in each runner of the exhaust manifold. As far as we know a more lean mixture gives higher EGT.
In this video my friend is cheating on per cylinder correction in the cylinder and shows the change of the EGT and mixture for all cylinders.
In another video check the interaction between the cylinders, as can be seen in the total mixture is changed, and the EGT stays the same.
I plan to add 2D or 3D tables for each cylinder, to trim EGT on all cylinders and check if any profit from this.
What do you think?
p.s Egt sensor in runners
https://a-a.d-cd.net/51bc0d6s-960.jpg
https://g-a.d-cd.net/c9bc0d6s-960.jpg
https://a-a.d-cd.net/e9bc0d6s-960.jpg
https://b-a.d-cd.net/5bc0d6s-960.jpg
mrfred
Dec 4, 2015 07:16 PM
desperado-c
Jul 15, 2008 06:35 PM
trinydex
Apr 10, 2007 11:19 PM
Boston'sEvO-->8
11
Sep 17, 2006 11:39 AM
Quick Reply: Per cylinder fuel trim
