Can this be done with our cars. WRX ecuflash Antilag
Old Feb 1, 2017, 12:03 AM
ant_turbo's Avatar
Was curious if this can be with evos
https://forums.nasioc.com/forums/sho....php?t=2540082
Old Feb 1, 2017, 12:31 AM
kaj
kaj's Avatar
Not sure if our cars work the same, but I'm curious.
Old Feb 1, 2017, 04:47 AM
TrendSetter's Avatar
just put your alt maps activation on a button and use your alt maps like that. easy enough.
i have that sort of setup in my launch maps, but that wont work if you are between gears while moving.
if you really wanted to implement that exactly like the wrx, it probably wouldnt be hard. lots of guys do that type of activation with stock ecus. the ls1 guys have been using it for nitrous enrichment for years. i know i could do it pretty easy on a 1g dsm ecu but im not smart enough to be able to dev on these newer ones with this fancier 16bit asm.
Old Feb 1, 2017, 08:15 AM
Biggiesacks's Avatar
The best thing to do is just use Tephramod V7 launch maps and No lift to shift to hold boost between shifts. Other countries got real factory Anti lag systems and a few have been able to implement them on U.S. cars. You could also just wire up a switch to activate the ALT maps like Trendsetter said, but those maps should be used for alternate fuel like e-85 or i suppose meth injection...
Lightsaber
Mar 30, 2014 01:04 PM
NorCal Lancer
Apr 19, 2007 04:54 AM
elhalisf
Sep 27, 2006 06:04 AM
USP45
Feb 27, 2005 08:38 PM
JF15
27
Jan 16, 2003 11:42 AM
Quick Reply: Can this be done with our cars. WRX ecuflash Antilag
