ECU can't read rom
Old Feb 26, 2017, 08:54 PM
strykr's Avatar
ECU can't read rom
So I installed the latest version of ecuflash and have the 13 usdm ralliart definition which is what I'm supposed to be running but I still can't read the ecu. The only thing I can save is a srf file which I can't read even manually forcing it to read in the Dev option.
Im not sure if I'm missing a step or the program just doesn't like Win 8? I also tried to run the program in admin mode with no luck.
Does anyone have an idea why I'm having trouble?
Thanks in advance.
Edit: forgot to mention I have a 14 ralliart
Old Feb 27, 2017, 04:06 PM
strykr's Avatar
Nobody has an idea? Ive been searching around and cant find anything, directories all seem to be pointing to their proper locations and i have the xml files.
checked using a hexeditor and line 50020 only shows ffffffff
Old Feb 28, 2017, 08:46 AM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
want to attach the srf file? I bet you have the incorrect definition. What is the ROM ID of the SRF file?
Old Feb 28, 2017, 11:30 AM
strykr's Avatar
I will upload it as soon as I'm off work, but it is 59570004
Daxter22 (May 28, 2018)
Old Feb 28, 2017, 03:47 PM
strykr's Avatar
As Requested, the link to my srf file.
https://drive.google.com/open?id=0B2...E5HeEY2Ykd0LWc
Old Feb 28, 2017, 06:33 PM
psfp's Avatar
Your rom id is 5957005.
Download 59570004 from Golden's website and this 59570005, which inherits 59570004 definitions:
https://drive.google.com/file/d/0B-f...ew?usp=sharing
SRF file format offsets things when compared to hex or bin formats. In SRF file, your rom id is located in 50141 address.
Old Feb 28, 2017, 06:40 PM
strykr's Avatar
I have both of those xml definitions and I tried using them with no luck?
Old Feb 28, 2017, 06:46 PM
psfp's Avatar
Well, it's working here. Show us your xml files.
Old Feb 28, 2017, 06:52 PM
strykr's Avatar
Well.... I feel like an idiot, the 004 file had (1) at the end. Just fixed it and now it works!!
THANKS GUYS!
MR Turco
Nov 27, 2021 08:08 PM
michaelukolov
Aug 30, 2018 03:09 AM
jameswwt
Feb 18, 2012 05:47 AM
Quick Reply: ECU can't read rom
