FP RED dyno results thread
Old Nov 7, 2008, 03:13 PM
Shacochis06's Avatar
Theres been countless threads of people posting about the fpred and info on it, and what kind of numbers they can make....
So lets start this thread with everybody with a fpRED to post there dynographs or anything they want about the Red
Heres mine: M2's, stock intercooler, block, ecu, 26psi, 93oct
Now i turned the boost up on a cooler day 30psi still 93 oct
Everbody with a RED post up anything you want (dynographs, track times, etc)
Old Nov 7, 2008, 03:16 PM
tkuoha's Avatar
nice power!
Old Nov 7, 2008, 03:24 PM
if you got one post it up
Old Nov 7, 2008, 04:31 PM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
2005 Evo RS
TBE no cat
Comp 280/280 cams with stock gears
RC 1200cc
Walboro
AEM intake
AGP FMIC
GM 3 port with ecu-controlled boost
FPred (steveoSpec porting)
Titek tubular 02 housing
SteveoSpec ported exhaust manifold
Forge WGA
Upper/lower IC hardpipes
Wilson/Indy Cali-spec intake manifold
Stock long block
Stock ECU
Car weighs 2700lbs
Road racing tune
110oct
30psi across
2006 Evo SE
COBB 3" TBE
MilSpec 100 cell cat
Cosworth 280/272 M3 mivec cams
HKS exhaust adjustable gear
RC 1200cc
Walboro
ARC intake box
3.5" ETS FMIC
Forge WGA
Nisei Upper/lower IC hardpipes
Stock long block
Stock ECU
Road racing tune
100oct @ 27psi:
91oct @ 24psi vs FPgreen at same boost and octane:
Old Nov 7, 2008, 05:13 PM
matt55's Avatar
[QUOTE=Shacochis06;6325387]Now i turned the boost up on a cooler day 30psi
[QUOTE]
Still on 93 ?!!
Razor , what are we looking at ? (mods,gas..)
Old Nov 7, 2008, 05:17 PM
9sec9's Avatar
Here's one of our recent dynos before changing to the GT3586HTA. I don't think it was our max power, but should be close.
If I recall, the actuator was a little 'loose' on this pull.
Old Nov 7, 2008, 05:47 PM
deuce329's Avatar
25psi on 93oct
31psi on 100oct
Stock Cams
https://www.evolutionm.net/forums/sh...d.php?t=373438
Old Nov 10, 2008, 03:38 PM
johnd's Avatar
fitted and mapped the Red over the weekend
got a dyno run today but was pretty disappointed with the figures
cheers
John
Old Nov 10, 2008, 03:42 PM
RazorLab's Avatar
another, Evo 9, M3, MilSpec Cat, usual supporting mods, 91 oct @ 25psi peak (dotted) and 110 oct @ 28psi peak (solid):
Old Nov 10, 2008, 03:44 PM
Import Junky's Avatar
Wow it seems as though the pump gas ones are a little hit and miss. It definately peforms better at higher boost. Luckily I'm using Alky. I'll be back in this thread in about a month or less to post my results as well.
Old Nov 10, 2008, 04:01 PM
RazorLab's Avatar
We are seeing 30whp+ gains over a FPgreen on 91 octane. I'd say that is worth the extra $100.
Old Nov 10, 2008, 05:15 PM
evo_gerard's Avatar
thats great, but at what expense in spool up time?
Old Nov 10, 2008, 05:20 PM
RazorLab's Avatar
300 to 400 at the most
Old Nov 10, 2008, 05:21 PM
you probably wouldnt even notice a spool up difference from the green to the red since its so minimal..
Old Nov 10, 2008, 05:28 PM
Magnumpsi's Avatar
I just did this last week. 91 octane 20-21psi with a cat. 2.2l
Mitch Mckee
Quick Reply: FP RED dyno results thread
