Mustang Dyno or Dyno Dynamics?
Dyno Dynamics poop all over Mustang Dynos. They are both eddy current dynos, you can adjust the ramp rate, and partial throttle load cell on both.
The difference is the software on the Mustang units is crude in comparison. The graph outputs look like color crayon drawings from Mustangs and the precision for graph analysis isn't there. The DD output is in real time, which I love if you have an event, because you can abort mid run. Heck, compare their prices. I've used a DD exclusively for 5 years and I'm not going back unless I have to.
i've also been curious about the many different dynos, and which one is the most accurate. Dynojet reads way high so I wouldn't even imagine that being one of the options for people that want a real figure. So does anyone really know or is it just opinionated for the Dynamic Dyno and Mustang Dyno?
A good Tuner can make-do with about any eddy current load bearing dyno and get the job done. A dyno is a tool and the tool is only as good as the operator.
The old adage that you get what you pay for is very true when buying a dyno. The inertia eddy current load bearing dynos cost more due to the additional material in the rollers. Couple this with a PAU control circuit with high resolution (needed for the tuner) and we narrow the view down to a few dyno manufactures in the US and the world.
DJ has always had a poor PAU control and low resolution, hence why shops like myself went to another dyno manufacture that produce a high resolution inertia eddy current load bearing dyno that does not need to use the eddy current controls to simulate ramp speed. DJ has very poor load control and resolution. Since DJ is the industry standard in the US I don't think they will change the PAU resolution anytime soon, but they have left the door wide open for MD and others to gain a big share of the market.
I have nothing agaist DD except I would like to see them produce a inertia eddy current load control dyno for VTEC and boost applications. I don't want to simulate inertia with eddy current ramp control when tuning in WOT.
Just my thoughts,
Frank
Just my thoughts,
Frank
What kind of precision for graph analysis do you want?? The MD displays raw data so you can see every dip or spike being made in the graph. You also have the ability to manually adjust both the Y and X to your likings.
The Mustang Dyno also has a closed loop feed back control that simulates load as if the car was on the street based on the weight and aerodynamic drag of the vehicle. This is something that the Dyno Dynamics can't do.
So why is a Dyno Dynamics $40,000 more than a Mustang Dyno????
Mustang output is real time, you can abort whenever you want. You can make whatever custom gauges you want to show information in real time however you want, digital, gauge, graphing, whatever. Mustang also has vehicle simulation mode that can simulate frontal area and road grade on the fly. Not to mention you can set a hold RPM where the dyno will not exceed that RPM so you can hold any gear, at any throttle position at that rpm if you so wish, same with speed. You can also dynamically change the load while doing any of the above.
The "crayon chart" is only one way to view the output, if you look at most of the graphs I have posted in the last year, it is in the non "crayon chart" output where you can specify whatever resolution and smoothing you want.
