E85 Fp black, stock block
Not to discredit your numbers, but the dyno reads higher than your typical dynojet. A single walbro & 1000cc injectors will reach 100% IDC around 500whp regardless if it's hardwired on E85. I'm guessing this car would put down 475whp on a dynojet. What were the uncorrected numbers?
uncorrected was just a touch over 500. guess ill take it to the track and get the numbers to back up my times
This dyno is NOT a dynojet, it is superflow and it can project dynojet numbers, it has been test against other superflows and dynojets that are local and numbers come out to be very very close
People have done 700whp on the stock FPR. The stock FPR is pretty good on our evo's.
Just to let you know, your car will not last with 475tq. It will blow rather quick. I can't believe your tuner pushed you that far on stock block. Here up in the NW we won't really go over 425tq. My car survived 1.5 years with 535hp/430tq and looked great when we took it apart but that was still to much tq than I really like to see on the stock block.
Mikey
Mikey
Mikey
Mikey
That's kind of a silly thing to say lol, there have been PLENTY of people that have done this amount of power for very long periods of time. We have an evo over here with stock block with over 100k miles that has been pushing 550whp and over 450wtq with a AMS 35r turbo kit for the past 4 years, and 40k+ miles no problems, and it has been abused from drag racing to hill climbs to autox events..
If the tune is happy and your not spinning the motor up to stupid RPM's the motor will be fine.
From my experiences it's RPM that will kill the stock rods along with a poor tune IE detonation, hard missfires ect. I've seen stock motors blow at 400whp and 350wtq, and I've also seen stock motors with close to 600whp and over 450wtq and not blow. It's a gamble you play when dealing with the stock block.
Your entitled to your opinion, but to claim that it will "blow" is fairly ignorant. You don't know that. It may, it may not, one fact that does remain is if you wanna play, you gotta expect something to break, regardless if it does or not. Racing and modding a stock block evo always has it's risk, regardless of power or tq...
This car is well under 475wtq when racing on a track (shifting at 7700rpm and falling back way above peak tq numbers), the owner of the car is not some idiot and knows his limits.
There was a write up somewhere but I can't seem to find it, but it's fairly easy to do. If you look at the top of the pump you will see a hole with a cap and a spring under it (it's kinda hard to see it but it's there) Find a punch that fits down the hole and sits on the cap perfectly and slightly tap the cap down till it is almost bottomed out.
