EVO 8 map ef4 bumper exit exhaust build / dyno
Thank you
Little update: Got to drive it some after putting in the walbro 450. Seems to be fine now. I don't know that the aem wasn't flowing enough, I think it was due to the suction filter on the aem sucking.. it's not rigid enough, and may have been just a bit too low in the tank still.
Also dropped the kelfords in, and the map upgraded springs, and a set of fidanza gears. Car just feels better all the way around. Picked up a little power, not as much as I figured with the cam change. Making around 510whp still with slightly less boost. I'm just happy it isn't having issues.. yet
Was going to go with aem gears so they would be black like everything else, but I got these new for $120 for both... so oh well.
Not sure whats up with the boost / afr readout. I mean it won't read afr because my wideband is standalone. And the boost isn't right. It spools at about 24-25 and tapers up to 29.5 (so at sea level it would be 21 ish to 26 up top). AFR go from 12.3 at intial full boost, taper down to 11.8 in the middle and back up to 12 up top
How did you get an ignition cut limiter? Are you using an ignition box?
Once I noticed this I re-enabled the launch maps. As I pulled the timing down in that area, it got more aggressive like the first video. Boost also came up.
In the first video, that was like 15 deg timing iirc, which isn't even aggressive, rpm was about 5400 and boost hit ~10 psi. In order to get the same result with fuel cut, I had to run -5 deg timing. If I lowered the timing on ign cut, I'm sure the boost would go completely crazy, but I was getting nervous about what might explode
Couple more videos...
Changed my exhaust setup tonight. I'm always looking for a way to make the turbo louder. Most packed / perforated mufflers cancel the turbo sound. The one I built was better, but killed it too much.
I found a muffler that doesn't kill the sound of the turbo.... because it really doesn't kill any sound at all
So I rebuilt the piece from the downpipe going out the bumper tonight. It's.... LOUD. I mean, the turbo SCREAMS .. but the car is so loud now it's actually retarded. Pretty much guaranteed an exhaust ticket first time out with this setup.
Haven't driven it yet to see if this areo turbine muffler actually flows worth a poop. It's the 4" version, but it's identical to the 3.5" inside from what I can see (I put one on my forester xt last night). I don't buy into all their "airplane" wing high and low pressure nonsense. I mean, I understand the concept - I'm a pilot. But airplane wings also create drag... so claiming it flows better than a straight pipe is hard to believe
Anyway.. an inside and outside video.. hopefully you can hear it.. the turbo is very loud in person.
Inside
Outside
Inside
Outside
My misfire at/around peak torque has re-surfaced it's ugly head again. I was back on stock coils because I had terrible trouble with the Honda COP doing this. I believe it was jump around the plug and grounding out rather than through the plug. Or maybe just weak and being blown out.. went back to stock coils and it worked great for well over a month. Suddenly it's randomly back.
After doing some reading, research and giving it some though. I'm going to go a little bit different route- LS2/truck coils. These are the big ones with the heatsinks built in. These work best around 3.2ms-4ms @ 14v. I bought NGK wires for a DSM to use with them. I was going to go with those AEM "smart" coils that don't require an igniter, but these GM coils don't need an igniter either, have similar spark energy, and are cheaper. And considered to be reliable and fairly popular swap on other platforms.
I'll keep everyone posted on how this change over goes, for future reference.
