Jason's 2.3L GSC S2 FP Black
Old May 18, 2016, 05:46 PM
JRally's Avatar
Car is an 03, 431whp/367wtq
2.3L Manley crank, 86.5mm Wiseco HDs
FP DBB Black MHI housing
Head has some bowl porting by ER
GSC S2 cams, Kiggly Springs/Retainers
FIC 900s and Walbro 255
Stock intake manifold and throttle body
Stock exhaust manifold
Open dump
Grimmspeed EBCS
ETS short route pipes and 3.5" intercooler
Tuned on 92 pump only so far until more fuel can be had
Right now the motor is out. Building it again with a few new parts:
Kiggly HLA
Eagle 100mm crank
Curt Brown 70mm ported intake
S90 70mm throttle body
FP Cast manifold ceramic coated
Ceramic coated turbine housing
One-off recirc downpipe
Coil on Plug
EGR deleted (was disabled, but all hardware was still there)
Radium fuel rail and pulse damper
I'm doing a bunch of other little things at the same time, and later I'll do a double pumper, 2150s and a FiTronic.
Hope to be updating this with new numbers before July, we'll see.
Old May 18, 2016, 06:44 PM
Jessica1985's Avatar
IMpressive numbers!
Probably no comments because theyre jelly! haha
Old May 18, 2016, 07:52 PM
JRally's Avatar
Originally Posted by Jessica1985
IMpressive numbers!
Haha I don't know about all that but thanks.
Old May 19, 2016, 02:39 AM
ctfpevoVIII's Avatar
How much boost? I would of thought you would of made a little more on a black even though it was only 92 oct .
Old May 19, 2016, 04:37 AM
wickedep's Avatar
am i reading that right...25psi by around 4K rpm? must be a nice drive mate...good work !!
Old May 19, 2016, 08:16 AM
JRally's Avatar
24lbs, was set up fairly conservatively as I was daily driving it at the time
24, ER's sensor reads 1psi high. It does spool nice and early though.
Old May 19, 2016, 08:22 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
That is awesome spool, a bit faster than my MHI red on the 2.0L. True shame FP went to a single scroll housing for the 9 turbo's..
Old May 19, 2016, 08:26 AM
JRally's Avatar
Yeah I've heard those new stainless housings kinda suck for spool.
Old May 19, 2016, 11:11 AM
4B11AWD's Avatar
Why are you replacing the Manley crank with the Eagle crank? Aren't they both 100mm?
Old May 19, 2016, 12:06 PM
JRally's Avatar
Because it's weak and they crack.
Old May 19, 2016, 01:36 PM
I actually missed the boost plot at the bottom of your graph, those are some nice #'s for just 24# of boost
Old May 19, 2016, 09:19 PM
Sloppy Hachi's Avatar
That sounds like a blast for a street car! I hope you make the jump to E85 soon to really maximize potential of that turbo. They are great!
Old May 19, 2016, 09:45 PM
JRally's Avatar
All in time. I've gone beyond my spending limit this round, so it'll have to wait.
Old May 27, 2016, 04:22 PM
Erik@MIL.SPEC's Avatar
That spool is impressive for a Black. Are you using hybrid boost?
Old May 27, 2016, 04:55 PM
JRally's Avatar
Just a Grimmspeed EBCS.
42revoincali
Dec 6, 2012 06:08 PM
Mivec
Australian Forum
Apr 30, 2003 08:17 PM
Quick Reply: Jason's 2.3L GSC S2 FP Black
