2.4 Evo builds using HX35/40 turbo!
so were you achieving full spool under 5k rpm? if so I think I had should have nothing to worry about especially with having a 2.4 stroker, ported head, etc
too high oil pressure from the OFH I imagine? what was your pressure?
Me having deleted the balance shaft and using GSC race shaft and oil cooler delete, my Evo is hitting 100 psi of oil pressure from cold starts and then lowers down to around 40 or so idling... crazy high but Im thinking about running the oil feed to the head but in fear of not supplying enough oil pressure. but on the other hand I do have a custom 12an drain that im fabricating that may still allow me to manage the high oil pressure as long as its draining it adequately.
I've always fed from the OFH with no balance shafts. My OFH is ported because I was getting 100psi+ at WOT. Now I'm around 65lbs. If you search Evo Holset you will see most if not all are feeding from the OFH.. You maybe want to reconsider.. Or maybe put a restrictor on there and tune for correct oil pressure.. Unless you want to blow oil seals... Good luck can't wait to see the results!!
I've been running a Holset on my DSM for about 5 years+.. The minimum oil pressure when the engine is on load must be 30 psi Maximum. Permissible operating pressure is 72 lbs although 88 lbs is permitted during cold start up. Under idling conditions pressure should not fall below 10psi.
but to chime in more on my setup I have an oil feed line with a fp restrictor coming coming from the oil filter housing currently, w/ a proper drain as recommended. Also I couldnt find a proper how to for porting the oil filter housing w/ pictures etc. its just on this brand new motor that high of oil pressure versus stock for my Evo is just concerning and im looking for a final take on what to do and be done with it with no worries.
Too much oil pressure kills Holsets, the DSM guys have written quite a bit on this topic.
I run a restrictor on our B series Hondas because those engines also have very high oil pressure especially with a modded oil pump and have had no issues with 'too little oil'.
That's why I'm thinking about running an unrestricted line from the oil feed at cylinder head... highly doubt it's possible to have stock oil pressure in the head when the bottom is achieving 40 psi once warmed up and at 100 psi on cold starts. I'll be sure to update this thread after the tune and final setup regardless! No one wants to kill a brand new turbo
That's exactly the plan... I really want to.. but not in a negative way, prove you dont have to go all out on a a traditional turbo that cost $1,700 + for just the turbo and still perform identical if possibly of better in comparison. or this will do just the opposite
turbodailydan
Jul 26, 2013 09:25 AM
canyonkid
33
Jan 10, 2012 10:10 PM
