EFR 9180 Break in tune 430whp 20psi
Old Feb 19, 2017, 06:43 PM
alpinaturbo's Avatar
Is there another dyno run that resulted in 430whp?
The dyno run posted shows ~400whp, just curious.
Thanks
Old Feb 20, 2017, 06:40 AM
03Roush2's Avatar
Thanks
alpinaturbo (Feb 20, 2017)
Old Feb 21, 2017, 09:14 AM
lancerrally45's Avatar
Sooooo, why havent you turned it up yet? After 20 miles I turned mine up to roughly 35psi lol. All you have to do is a compression check to make sure the pistons rings are seated.
Old Feb 22, 2017, 10:59 AM
03Roush2's Avatar
Everywhere Ive read said to do at least 500-1000 miles with low/no boost. But the biggest issue is the clutch went on me after 200 miles, not sure why. It was used so I'm thinking maybe a worn pressure plate. But I have a triple to swap just need to get it to a shop to get it taken care of.
Old Feb 24, 2017, 07:16 AM
Everyone has their own preference when it comes to breaking in the motor. My opinion and what Ive always followed, drive it like you stole it. If its going to break its going to break, be it at 20 miles or 2000 miles. As long as you have a good amount of compression and ring seat, youll be fine. Plus boost helps the rings seat
Never had 1 engine go from the handful Ive built.
Sad to hear about the clutch. I want to see what this car has in it.
The following 2 users liked this post by lancerrally45:
kizzlecake (Oct 15, 2019), Meathooker (Mar 12, 2017)
Old Feb 28, 2017, 06:14 AM
flexer's Avatar
Two different ideas really on breaking in a motor. I have always gone with the 1-2 hour break in of mototune. Here is more info:
https://www.enginebasics.com/Advance..._Break_In.html
Old Mar 1, 2017, 10:36 AM
Yup, I would agree with the above link. Total run time for me was maybe 45 mins at max between letting it heat up and then come down, then reheat and go.
Old Mar 1, 2017, 12:15 PM
03Roush2's Avatar
Yeah I think i will be turning it up soon. Clutch is going in next week Im going to drive it a little, compression test and dyno.
Old Mar 2, 2017, 12:22 PM
New clutch on the other hand, I would break that in differently. Get a few hundo on it before you go too ham.
Old Mar 2, 2017, 04:21 PM
LetsGetThisDone's Avatar
Received 1,542 Likes on 1,321 Posts
A brand new clutch will hold power doing dyno pulls just fine. You just don't want to launch with it or do any fast shifting or down shifting with it where it will slip.
Old Mar 3, 2017, 07:36 AM
Not where IT will slip however where the USER slips the clutch. You want to avoid these situations until it is broken in.
JohnBradley
Mar 5, 2019 08:12 AM
simonevo900
Jan 21, 2016 11:17 PM
salvatruco2004
Aug 13, 2015 07:59 PM
DRAG
17
Jan 25, 2015 01:56 PM
srt4killer
27
Nov 8, 2014 09:19 PM
Quick Reply: EFR 9180 Break in tune 430whp 20psi
