Looking for a map for evo8 with 9 turbo
I have an evo 8 with an evo 9 turbo, evo 8 stock cams and stock injectors.(I have ide 1130 ingectors sitting in my room I don't know if they are necessary for my 350 whp goal on pump gas.)Have the full turbo back exhaust and injen intake with intercooler.
was wondering if anybody had their evo tuned with similar parts on it. I know this is a pretty common set up. I just need a map where I can start from and use ECU tune fix the map up a little bit.
I am Kinda new to tuning but I figured if I really monitor my exhaust temperature and air fuel ratio i should be OK. If you have any advice let me know. Because a tune will cost me around $500 if I go to a shop in the Seattle area. I don't know many places around here that tune evos.
For your goal of 350 the stock injectors are fine. I've seen similar combos but with 272 cams and they performed well. I would say invest in a pro tune it will be best especially if your new to tuning. I would recommend an e-tune from TSCOMP or Pure Drive Performance as they will take the time to explain what they are doing so you are aware of all the changes. A single MAF tune is normally around $300
^^ This. do it right the first time. if you dont have the money yet, just save for a little bit. No two cars are the same, even if they have the complete same mods. i wouldn't play around with having someone else's tune on my own car. English Racing is the way to go!
novaspyder87
Mar 18, 2016 08:00 AM
whiterexman
19
Dec 29, 2004 07:06 PM
han74j
Mar 17, 2004 05:42 AM
