Evo IX stock block big power 624whp | JDL T3 6266 S3 E54
One of many high horsepower stock block Evos we tune here. Morgan recently switched from stock cams to s3 and here are the new power numbers. I can share before & after as well if anyone's interested in that. We recommend you always stay under 400wtq, however this customer likes to push his car at times. I've been tuning this car for almost 3 years now at very high horsepower levels.
This car has gone a best of 10.7 @ 136 when it was around 560-590whp.
Car is located in AZ, so temps roughly around 60-70F or so.
Fuel quality was E54
624/451tq @ 33psi (Track race map only)
598/412tq @ 32psi (Race map)
554/390tq @ 27psi (Daily driver map)
Mods:
Stock block (98K original miles)
JDL T3 kit with PTE 6266 JB .82 A/R hotside
FIC 1450cc injectors
GSC S3
Double pumper
Grimmspeed 3 port
Muse IC piping
Buschur FMIC
Synapse BOV
ARP standard head studs
Extremepsi 4" SD intake
3" TBE
Tephra v7 SD /w ecuboost
Mods:
GSC S3
Double pumper
Grimmspeed 3 port
Muse IC piping
Buschur FMIC
Synapse BOV
3" TBE
why the drop in tq above 7300 at 33psi even though you ramped boost up? Is it less timing with that boost vs the 32psi pull? Would've expected tq to be flat and hp to keep climbing based on the 32 pull and wouldn't think it would be out of turbo.
Not judging, just curious!!
The 32 psi Race map has a mean curve
Technically torque increases with HP, so while the curves falling off its still being gained when your tuning the vehicle. You tune a car with torque not HP. Hope that made sense.
He is aware of the consequences.
If it had a built engine, it would need bigger injectors and ported intake mani and bigger throttle body next. Preferably Skunk2 intake mani ported by us + Fullblown 70mm.
tscompusa
Oct 9, 2017 05:44 PM
tscompusa
Nov 16, 2016 09:46 PM
SmurfZilla
Jul 19, 2016 02:04 PM
DG Motors
Sep 27, 2009 05:38 PM
