another evo viii and ix alarm wiring diagram
2005 MITSUBISHI LANCER 4DR SEDAN EVO VIII
Security
WIRE COLOR POLARITY LOCATION
Battery WHITE (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK/WHITE (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger WHITE (-) FUSEBOX , WHITE PLUG AT BOTTOM
Domelight Super USE DOOR TRIGGER
Trunk Trigger GREEN/ORANGE (-) TRUNK LIGHT
Alarm Disarm GRAY
Parking Lights GREEN/YELLOW (L) GREEN/WHITE (R) (+) FUSEBOX , WHITE PLUG AT BOTTOM
Convenience
Headlights-Lo RED/YELLOW (L) PINK (R) (+) RELAY CENTER UNDER HOOD
All Hazrd Lights WHITE (-) HAZARD SWITCH
Wipers-Lo BLUE/RED (+) WIPER MOTOR
Wipers-Hi ORANGE (+) WIPER MOTOR
Parking Brake BLUE/RED (-) PARKING BRAKE SWITCH
Remote Start
Accessory 1 BLUE/BLACK (+) IGNITION SWITCH HARNESS
Accessory 2 BLUE/WHITE (+) IGNITION SWITCH HARNESS
Anti-Theft Type SOME MODELS HAVE RF TYPE IMMOBILIZER SYSTEMS
Key Sense BLUE
RESTS AT GROUND OPEN WHEN KEY IS IN, USE RELAY TO OPEN.
Tachometer BLACK/YELLOW (-) IGNITION COIL
Speed Sense BLACK/RED (AC) DIAGNOSTIC CONNECTOR UNDER DRIVER DASH
Brake Lights GREEN (+) BRAKE SWITCH
Reverse Lights BROWN (+) DRIVER KICK PANEL, HARNESS TO REAR
Horn BLUE/RED OR RED (-) HORN SWITCH
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock LT.GREEN (-) DRIVER KICK DOOR HARNESS
PowerLock VIOLET (-) DRIVER KICK DOOR HARNESS
Driver Mtr Unlock WHITE (REV) DRIVER KICK DOOR HARNESS
Driver Mtr Lock BLUE/RED (AC) DRIVER KICK DOOR HARNESS
LF Window Up RED/BLACK (REV) DRIVER WINDOW SWITCH IN DOOR
LF Window Dn GREEN/BLACK (REV) DRIVER WINDOW SWITCH IN DOOR
RF Window Up BLUE/WHITE (REV) DRIVER KICK DOOR HARNESS
RF Window Dn BLACK/WHITE (REV) DRIVER KICK DOOR HARNESS
LR Window Up WHITE (REV) DRIVER KICK DOOR HARNESS
LR Window Dn BLUE (REV) DRIVER KICK DOOR HARNESS
RR Window Up BLUE/BLACK (REV) DRIVER KICK DOOR HARNESS
RR Window Dn GREEN/YELLOW (REV) DRIVER KICK DOOR HARNESS
Security
Alarm Disarm GRAY
Convenience
Remote Start
Key Sense BLUE
Modules
WIRE LOCATION
Doorlocks/Windows
I just did the wiring this morning... all seem right except for the power door unlock. It wasn't purple, it was yellow! Thankfully there was only like 50 wires to keep on tapping to see if it would get the door to unlock
lol prob not me, my dad goes to the bay sometimes(nearest place to get serviced) he might have caught you on the freeway..but never said anyhting to me. Do you remember the lisence plate? its hard to miss; AWD V12
