Alternator Charging issue
I have an 06 gg se I have been having issue's driving the car. The car will not stay running. I have checked the alternator twice (taking it to an autoparts store and running it outside the vehicle) both times testing just fine. i have also bought a new yello top battery. When the battery is getting low on voltage the car idles at 2200rpm and all the lights dim. I have not changed anything on the car since last year same gauges, radio nothing new in the electrical department. If i could get some opinions and help ive had enough and ready to drive it off a cliff.
Old bump having the same issue new battery and alternator with no luck, also tried a separate ECU. The fusible links on the battery cable are good.
Its just not charging the battery...
Another note the battery light doesn't come on when the key is in the on position, took the dash apart and the bulb is good and no short
Help!!!
Help!!!
hey guys i have ran in to this problem on a guys car i replaced the alt thinking that it was the problem becuse all sings point to it but it was a remaned alt i also checked the wires that controll the voltage regulater and they all seemed to be with in spec as far as the resistance in the wires here is a diagram that i used if needed i will tell step by step of what i did to come to the conclusion that it was the remaned alt new alt coming from mitsu
ok so im having the same prb in my 04 evo 8. i replaced couple alternator from mitsu. put 5 new batterys. checked my wores. added grounds. its only sending 12.2v. i was thinking one of the wire from the ecu is bad so im gonna run new wires. if that didnt work i will try and you guys should change the ignition switch. nd if you have problem with th starter it could be a problem too, good luck
Help!!!
Help!!!
I am experiencing this same exact issues as most of you. My car will run fine while the battery has a charge, then all my lights start dimming and engine starts to die off. It died on me on the highway just recently. I got a jump and it fired right up. Its a brand new battery and when its charged it puts out 13 volts but I checked my alternator and its putting out anywhere between 14.5 to 15.9 volts. Thinking its the alternator since its internally regulated. will be pulling it this weekend to replace.
