Evo V won't start after timing belt and CPS change
Old Nov 6, 2014, 08:35 AM
Yazer's Avatar
So my evo died during driving. Found out my balancer belt was cut and destroyed the crankshaft position sensor. I changed the timing belt at the same time but now my car doesn't start. My battery was gone empty because car stood in garage for a month waiting for a motivation to fix it.
Yesterday i tried to start the car after belt, CPS change and loading battery, but it doesn't start. Keeps cranking, gets spark and fuel but nothing happens. There is no generator belt installed atm though so might it prevent starting?.
I didn't get spark at all before changing crankshaft position sensor, now there comes spark after installing a new one.
Old Nov 6, 2014, 02:15 PM
Ev0ikon's Avatar
No Alternator belt?
Old Nov 6, 2014, 07:26 PM
Yazer's Avatar
Nope. Wanted to give a test start before installing it.
Old Nov 7, 2014, 12:46 PM
Ev0ikon's Avatar
Ok. I would check sensors (Crank and Cams), then timing again and make sure cams are timed correctly. If they are all good I would do a leak-down test. Hope the timing belt didn't jump.
Old Nov 7, 2014, 08:34 PM
alpinaturbo's Avatar
You may have missed to plug in something, like coils, or injectors, or TDC/Cam Sensor.
There is no problem, its a simple omission
I am sure its electrical-sensor related...
Let us know.
If you don't find it, I'll connect you to your fellow countryman who can speak to you to help you out.
Old Nov 7, 2014, 11:17 PM
Yazer's Avatar
Checked all wirings, there was one engine grounding loosened, but tightening didn't help.
Could my ignition be 180 degrees off, because it's backfiring occassionally to my valve cover breathing pipe when trying to start? Wondering how it is possible though because i've checked timing marks many times. I'll try today with a new camshaft position sensor and hope for the best.
Old Nov 8, 2014, 03:01 AM
todd6027's Avatar
check coils/leads/connectors are on the right cyls ,simple one i know but it has been done
Old Nov 8, 2014, 03:13 AM
Yazer's Avatar
Ok i double checked my valves, lifters and all.. Found out my intake valves are broken. Lifter/cam backslash is about 4mm (valves doesn't come whole way up). I could take lifters away with my fingers.. Didn't notice it before because there was so much oil on lifters. There was few lifters stuck between cam and valve so it felt like everything is ok when I rotated the engine by hand. Looks like my timing had jumped a whole way around from crankshaft, that's why it looked like timing had jumped only 1 tooth when I checked everything before changing timing belt.
Old Nov 10, 2014, 01:12 PM
Ev0ikon's Avatar
Sorry man. It's what I suspected too. It's so easy to ding/bend the valves on these engines just a tooth or 2 off.
Tagge
10
Dec 23, 2012 05:20 PM
dsevo
29
Dec 10, 2012 03:01 AM
Delux247
10
Nov 28, 2012 09:28 AM
Blue91lx
May 16, 2012 08:35 AM
anthonypazsd
Jan 31, 2010 03:01 AM
Quick Reply: Evo V won't start after timing belt and CPS change
