evo 8mr wont start after removed key chip
Old Mar 18, 2016, 04:28 AM
xjy19860421's Avatar
Hi, I only have one key it working perfectly, and I bought a new key case to replace my old key coz key cover cracked. So I put my old key chips to my new key case, but I forgot it and just start the engine with my old key but without chips. engine running for 3 secconds then stop, try start again , engine can not start anymore. feels like immobilizer cut out fuel pump.
try to code the key with my scan tool, it said need key registration code but I could not find it where it is.
then I google it, try to get wire to bridge obd plug terminal 1 and 4, press hazard light button 6 times, I can hear lock and unlock means get in code key mode, then I press lock button in the key 3 times and unlock , then took wiring off obd plug, still can not start the car.
does anyone have tips for that?
Old Mar 18, 2016, 07:35 AM
Biggiesacks's Avatar
I don't have an answer for your specific question, but I would highly advise you to just disable it and install some other security. A good alarm plus a kill switch would be my advice. The factory immobilizer is basically worthless as a theft deterrent.
Old Mar 18, 2016, 07:56 AM
llDemonll's Avatar
Evos need the chip in the key present to run
Old Jun 18, 2016, 11:09 PM
Fox_IX's Avatar
Flash your ECU with the immobilizer disable patch or if you are unable/unequipped to do so take it to a tuner and ask them to disable the immobilizer.
yourboysevo9
May 8, 2016 05:14 AM
ca18hatch24
Jul 25, 2014 02:28 PM
Chriso3030
10
Aug 19, 2009 05:11 PM
Quick Reply: evo 8mr wont start after removed key chip
