my wipers and turn signal blinker problems
Old Oct 27, 2016, 10:34 PM
Evoguy!123's Avatar
hello, so my car been acting up, its been raining this week and my turn signal just stayed on, not blinking just stays on. Also my blinker stays on when its literally off and cant turn it off unless my car is off. checked fuses there all good. Any ideas what could of caused it?
Old Oct 27, 2016, 11:25 PM
Pal215's Avatar
Odds are you have water where there shouldn't be. Start here and see where this takes you.
https://www.evolutionm.net/forums/ev...s-how-fix.html
-pal215
Old Oct 28, 2016, 04:41 AM
gsrboi80's Avatar
-pal215
Yes sir!! What he said. You have corrosion in the connectors behind the drivers side left foot kick panel. Nothing some solder and heat shrink tubing can't fix. I've done >10 at this point.
Good Luck, Check twice, Cut once.
Old Nov 1, 2016, 04:18 PM
jpete709's Avatar
did you ever find out why its keep getting corroded? water?
any rubber grommet nof secured? or if you have runroof, possible clogged drain tube?
keep us updated, just wanna know lol
Old Nov 1, 2016, 06:46 PM
gsrboi80's Avatar
Mine has never corroded again. Rain gets in behind the fender via cowl, removed/worn fender plastics, worn/removed hood seal rubber, etc...
The grommet that the harness from the fuse block under the hood runs through that grommet. Apparently some of those grommets don't seal well, become compromised, or it's a design flaw from Mitsubishi. Water gets through the grommet, runs down the harness (it doesn't take more than a drop here and there even) and gets to the pins on the back side of the connectors. Then you end up with this lovely dilemma.
Old Jan 26, 2017, 10:49 AM
Evoguy!123's Avatar
yes, driver left kick panle. need to seal the rubber around it in order to not get water in the connectors
evo4g63awd
Jan 14, 2014 04:55 PM
knuckles05
Dec 17, 2013 03:47 AM
stealthyevoviii
May 5, 2011 06:39 PM
squid267
Lancer Troubleshooting
Mar 23, 2011 02:27 PM
e v o
Oct 11, 2006 09:39 AM
Quick Reply: my wipers and turn signal blinker problems
