Door Warning light
Door Warning light
HI Guys, I'm driving 2003 JDM Evo8 RHD.
My problem is the Door warning light is not "ON" when either one of the door opened. Check the wire connector/room light/buzzer is all ok and function as original. Bulb ok, try to loop -ve wire to connector pin at meter 34 , the lights goes on...in reality that pin had no signal, pin 8 got voltage supplied.. After check all, still the light is not "ON". Have you guys have this experience ? .
Could be a bad switch. Mine was bad when I got the car. I swapped one from the rear doors to test on the driver side (which was not working) and then it worked. Both actually worked once I did the flip flop. Also make sure there is no corrosion around the screw that hold it in.
Good Luck!
Good Luck!
Good Luck!
Good Luck!
I'd go buy a new switch to see if that would alleviate any of the problems. In terms of the fog and headlight signal, I cannot answer with confidence but it sounds like a wiring problem somewhere. Might want to check a fuse for that. I am by means no expert, but have gone through some issues myself. Hopefully something with work for you.
Evolution8RS
Feb 27, 2009 08:51 AM
OSiTO-PANDA...
Mar 22, 2007 12:51 AM
Gruppe-S
Evo 'For Sale' Exterior Styling
22
Jan 23, 2007 02:09 PM
