Helix Cat Delete
Helix Cat Delete
Question to you guys with the Helix cat delete - in what orientation did you install it? The O2 sensor bung, is it facing toward the front of the car or toward the back? Anyone with pics? I installed it facing the front and I'm triggering an SES light... let me know and thanks!
Originally Posted by evo81
i have mine facing towards the front,and i still get a ses light
Originally Posted by Gonzo0991
^WTF?! I thought they had fixed it so no lights would come up? Maybe I was miss informed?
UR same as Helix?
I have my UR test pipe installed as pictured below. I have not yet gotten a SES light. Is the Helix the same as the UR test pipe? From the pictures I've seen it appears as though the 02 sensor "canal" on the UR pipe may be a little bit longer than the one on the Helix pipe. If that's the case, the spark plug anti-foulers may work.
Hrmm so there are more ppl with my same issue.... anyone with success?
naucrx: The Helix pipe is similar to the UR, except the o2 sensor bung is a bit shorter... I also have my pipe installed backwards from how yours is oriented.
ok....i decided to try the anti plug foul thing..and looks like it works so far...200 miles and no SES light...b4 i would get the light back on after 50 miles or so...after i reset the ecu...i tried this like 3 times and everytime around 50 miles i would see it..so far so good...u guys should try it...
nemesis
Jun 9, 2005 02:37 PM
schleppy
Sep 25, 2004 10:29 AM
