DTC P0122: Throttle Position Circuit Low Input
Old Sep 9, 2013, 05:24 PM
x03_EVO8x's Avatar
Bumping this back up as I just recently got this code. Couple weeks ago I replaced plugs and wires. About a week later I got 2 codes that came up. First one was front O2 sensor and the other was the TPS which says low voltage. I just replaced the O2 and cleared the codes. TPS code came back instantly. Hoping it could be a fix without replacing since they are about $180. Any input???? Appreciate it!
Old Sep 19, 2013, 07:02 PM
kamote2000's Avatar
bump for this thread, keep getting this code on random, finally got tired and replaced the TPS. a few days code came back twice on the same day, cleared the trouble code as of now and waiting if it will come back on again. if it does, what to do next?
Old Dec 20, 2014, 05:54 PM
RcEvo09MR's Avatar
Any Up dates on this issue to get resolved?
Old Mar 28, 2015, 06:22 AM
fugiwara's Avatar
bump
Old Mar 28, 2015, 05:12 PM
kamote2000's Avatar
Used evoscan to set the tps at 13.33% at idle. Used sas mode to park iacv and dial in the biss screew at 900rpm at idle somehow code never came back again.
Old Sep 27, 2023, 01:33 PM
WelDun1's Avatar
Originally Posted by fitch
Got the same code... Car hesitates now.... Put the car on a scanner..... Suppose to be a flat line during idle BUT it goes down then steady then down.... Not good!!!! OEM TPS is around $180.... Freaken EXPENSIVE!!!!!!!!!
I bought a sensor from Car parts
Evo 8/9 TPS Sensor $11 shipped
kamote2000
Sep 30, 2016 10:50 PM
Boosted4
Apr 12, 2014 01:07 PM
Indianbrandon
Dec 28, 2012 01:20 AM
Mortis
Jan 11, 2011 05:09 PM
Nesiop
Aug 12, 2009 09:38 AM
Quick Reply: DTC P0122: Throttle Position Circuit Low Input
