MSD 6A Ignition or AEM ignition
Anybody have tried both the ignition systems?
I'm thinking of getting one but do not know which to get?
With stronger sparks, do we need a colder spark plug?
Please advise....
Thanks?
Please advise....
Thanks?
Do you have an aftermarket turbo? There is little gain or difference in an ignition system under the 375 AWHP level. You may notice a small change but not enough to warrant the price. You'd know when you were blowing the spark out and a high power ignition is necessary. Personally, I am going to get the coil on plug/AEM setup that is sold by several vendors when I need an ignition. I'm at 340 AWHP and haven't found the need.
Hi there,
Thanks for the valuable inputs....i'm currently at 382hp, i'm not sure whether i need..
Do you have any ideas what are the some of the causes of mis-firing at high rev?
no, no...its 382 at the engine....if its the wheel, i would have a big grin on my face now...haha....
If you have 382 HP at the wheels then you could probably see some benefit from having an ignition setup. You can also increase your plug gap a little bit too with the ignition.
Although its not a required upgrade, and most tuners say its not necessary, I tend to disagree.. But not so much for the better "performance" reasons, since you really need to be dealing with ignition problems such as high boost blowing out the spark or other issues quenching the spark..
What nobody takes into account is when you run colder plugs, and bigger gaps, and slightly higher boost, you get some level of misfire in daily driving which an improved ignition system can will with. Also, an upgraded ignition system will "Start" the engine easier when its cold.
There is definitely benefit to be had with an upgraded ignition..
WITH THAT SAID, the only plug and play setup available currently to use the stock coils is the HKS-DLI2
If you use an AEM C2DI setup, you might want to step up to a coil on plug setup, but at the least your going to have to upgrade your stock coils.
For the expense, there's not much tangable gains to be had from a performance standpoint, and that is why most don't recommend this type of upgrade unless your making quite a bit of horsepower.
You do need a 2 channel ignition upgrade though, which means an MSD 6A box will not work..
I am currently in the process of fabricating my own coil "per" plug setup using the AEM CDI and 4 MSD Blaster SS Coils. I am changing due to one of my coil packs going out the other day, had the CDI laying around and ordered the coils from Summit. Using some 2g DSM plug wires from Taylor and mounted the coils to the plate that held the small battery from Buschur and re-located the factory battery to the trunk. Going to wire the coils in series using only 2 triggers off of the AEM EMS, not 4, running waste spark. Total cost is much less than what I have seen elsewhere.
Your doing the same thing I'm doing, only I'm using Honda Motorcycle coils since they fit under the plug cover and generate better output than the stock coils they also refresh much faster, which means the multi-spark discharge feature at idle and low RPM works better. I'm missing the connectors off a set of stock burnt out coils.. anyone got a set? PM me..
