My 10.5 Hotside Install & How-To
Old May 30, 2009, 10:36 AM
  #346
leecavturbo's Avatar
Originally Posted by mrfred
Looks amazingly easy.
yeah some of these just don't play ball . seized bolts and nuts and the space is tight compared to alot of cars you'll work on.
i left my manifold on so had to take out the radiator for room to get the housing out.
Old Jan 13, 2010, 08:00 PM
  #347
franc01's Avatar
To the OP- do you definitely have to take off the undertray to do this or can you get to the stock O2 housing bracket with it still on? I know I can unbolt the downpipe with the undertray still on.
Thanks!
Old May 20, 2011, 09:33 PM
  #348
Thoe99's Avatar
Is it possible to use bolts (instead of studs) on all 5 of the 10.5 hotside's connections to the o2 housing?
Old May 21, 2011, 05:12 PM
  #349
Thoe99's Avatar
So the answer is that you can only replace one of the studs with a bolt (the bolt showing in the pic below). Due to the shape of the o2 housing, it's not possible to replace the other one with a bolt. There's not enough space to thread a bolt through this hole.
Old May 21, 2011, 07:39 PM
  #350
sparky's Avatar
I have my O2 fastened with 5 bolts and no studs. So, it can be done.
Old May 21, 2011, 07:50 PM
  #351
Thoe99's Avatar
Is your o2 a dump? Maybe it's shaped differently, but on a Megan o2, it won't happen.
Old May 21, 2011, 07:53 PM
  #352
sparky's Avatar
The trick is that 4 of the bolts can have the 17mm bolthead size whereas the 5th bolt(the lowest down) has the same bolt shaft diameter and thread but a smaller head size(14mm I think). Do you comprendo?
Old May 21, 2011, 07:55 PM
  #353
sparky's Avatar
No mine is not a dumpster. It is an EBay O2 housing.
Old May 21, 2011, 08:02 PM
  #354
Thoe99's Avatar
Do you have a part number for that particular bolt?
Old May 21, 2011, 08:12 PM
  #355
sparky's Avatar
I pretty much explained it in my post #352. I used a non-Mitsu bolt that had a smaller head size. I fished it out of the Planter's Peanut tin can. It is the same shaft diameter and length but has a smaller head.
Thoe99
Nov 13, 2010 06:30 AM
KK
Oct 15, 2008 07:51 PM
ArchieBabes
Sep 19, 2006 02:46 PM
vegasboy301
May 11, 2006 07:38 PM
vegasboy301
Jul 26, 2005 02:05 AM
Quick Reply: My 10.5 Hotside Install & How-To
