My 10.5 Hotside Install & How-To
Old Apr 9, 2005, 04:44 PM
SuperHatch's Avatar
Interested in installing a 10.5 Hotside? Not a big fan of having to pull your turbo? Read up!
So I decided to install a 10.5 Hotside and a Megan Racing O2 Housing before getting dyno tuned again. Here's what I bought and what you'll need to do the install. You'll need everything here minus the O2 to install a hotside if you want to retain your stock O2.
The first thing you'll have to do is remove the stock undertray, and downpipe. These are simple tasks to I didn't take pictures. Once you've got those parts out you'll look up at the stock turbo outlet and see this...
^ Remove the black bracket holding the O2 housing to the Block. You're done under the car for now.
Next remove the manifold heatshield...
Then the O2 Sensor and the lower heatshield...
You'll have to disconnect the O2 sensor under the coil pack cover...
Attached Thumbnails My 10.5 Hotside Install & How-To-img_0126.jpg   My 10.5 Hotside Install & How-To-img_0128.jpg   My 10.5 Hotside Install & How-To-img_0130.jpg   My 10.5 Hotside Install & How-To-img_0131.jpg   My 10.5 Hotside Install & How-To-img_0132.jpg
Old Apr 9, 2005, 04:49 PM
SuperHatch's Avatar
You'll need to pull this clip to remove the wastegate actuator arm from the Turbine Housing...
Voila!
Then you'll need to remove the manifold. Once you have everything unbolted, it will take some convincing to get the manifold out. But trust me, it can be done, as seen below....
Once the clamp is off, slide the turbine housing and O2 housing off together, and be VERY careful not to damage the turbine blades.
You'll then need to remove the v-band clamp holding the hotside to the turbo's center section. Depending on the orientation of the clamp your's might not be as easy to get to as this...
Attached Thumbnails My 10.5 Hotside Install & How-To-img_0133.jpg   My 10.5 Hotside Install & How-To-img_0135.jpg   My 10.5 Hotside Install & How-To-img_0136.jpg   My 10.5 Hotside Install & How-To-img_0138.jpg   My 10.5 Hotside Install & How-To-img_0139.jpg
Old Apr 9, 2005, 04:55 PM
SuperHatch's Avatar
This is what it looks like with the turbine housing out, the turbo is held securely in place by the coolant and oil hardlines...
This is your friend, use it on EVERYTHING you put back together!!
You'll need to attach the O2 housing to the Turbine housing before putting it in the car. You will need to use NEW STUDS where they were on the original hotside. The hotsides do not come with them and even if you are able to get them out of your stock hotside, chances are the threads will be destroyed. So do yourself a favor, order them ahead of time and have new ones ready.
Installation is reverse of disassembly. Total install time... 4 hours for me. Hope this gives some of you DIYer's some confidence to tackle this. Good Luck!!
- Steve
EDIT: Here are the torque specs...
Attached Thumbnails My 10.5 Hotside Install & How-To-img_0140.jpg   My 10.5 Hotside Install & How-To-img_0147.jpg   My 10.5 Hotside Install & How-To-img_0148.jpg
Old Apr 9, 2005, 05:00 PM
westchester evo's Avatar
wow great work !!!!
Old Apr 9, 2005, 05:02 PM
Compjoc's Avatar
awsome write up man. I might have to do this mod too.
tcarretti's Avatar
Thumbs up Great Job!!
Let me say that this was a GREAT write-up! This actually looks like something that I could do by following these directions. Great job man!
Old Apr 9, 2005, 05:04 PM
Wicked05's Avatar
yeah..that's some big cajones to tackle that job....AND with turbo still in the car....
............here ....have one on me....
good job......
Old Apr 9, 2005, 05:06 PM
evo_whiplash's Avatar
Thank you for doing a write-up. What are your impressions so far?
Old Apr 9, 2005, 05:07 PM
GreedMOTO's Avatar
Man I thought I was gonna be done modding for a while....good job!
lets see how much it picks up on the dyno.... cool
Old Apr 9, 2005, 05:08 PM
tasco's Avatar
Awesome write up, Ive been looking for one for a while. Let us know how it feels!!
SuperHatch's Avatar
You're all welcome, thanks for the compliments guys...
My impressions... it sure looks nice!!! I havn't driven it yet, I'm driving up to TurboTrix tomorrow to have Shiv tune it, I don't wnat to drive around with a current custom tune that doesn't account for it and mess something up. I'll let everyone know the improvements after I get tuned tomorrow.
Old Apr 9, 2005, 05:10 PM
mark and jeff at TURBO TRIX will make some numbers. Im going to go with the turbo with the
titainiam wheel and the 10.5 hot side, I think its the one on the MR. good luck.....
Registered User
Whooopasss's Avatar
thanks a bunch man!!!
Old Apr 9, 2005, 05:13 PM
SuperHatch's Avatar
I'm sure they would, but Shiv will be there tomorrow, it's a Vishnu Dyno Weekend. We'll see where my numbers go from what's in my signature now...
Quick Reply: My 10.5 Hotside Install & How-To
